User Tag List
Results 1 to 6 of 6
Thread: PV Disconnecting means
  1. #1
    Join Date
    Apr 2015
    United States
    Posts
    43
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The Utility companies in Michigan require a AC disconnect between the inverter AC output and the back feed breaker in the electrical panel, to be located in proximity to the utility meter. If i am installing a service disconnect off the meter and converting the existing electrical panel to a sub-panel, can the new service disconnect be also used as the solar AC disconnect ? (they serve the same purpose). Where can i find verbage to validate this /
    Thank you
  2. #2
    Join Date
    Oct 2009
    Austin, TX, USA
    Posts
    10,408
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Eros View Post
    Thank you
    I don't think so. Most utilities want to be able to shut off and lock out the solar feed without affecting anything else.
  3. #3
    Join Date
    Jul 2012
    Chicago, IL
    Posts
    27
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you
    You should be able to get the exact language directly from the utility. They should have a person or group that handles interconnections that can help you out.
  4. #4
    Join Date
    Sep 2014
    dallas tx
    Posts
    1,640
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Line side tap, back fed ,service disconnect to combiner and probably a few other methods all have one thing in common. They all will have a service disconnect grouped by the meter.
    The hardest faults to clear are mine
  5. #5
    Join Date
    Oct 2009
    Austin, TX, USA
    Posts
    10,408
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by electricalist View Post
    Deleted
  6. #6
    Join Date
    May 2011
    Posts
    4,860
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you
    Your description is a little unclear. Why are you installing the new service disconnect.
    If you're doing a supplyside connection and will have one new disconnect for the loads and one new disconnect for the solar, then the latter can fulfill your utility requirement, I would think.
    If the new service disconnect is being put in for some other reason and will disconnect more than just the solar from the grid, then it won't suffice.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
