User Tag List
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: Cat 6 termination, A or B?
  1. #1
    Join Date
    Jul 2017
    COLS. OH. USA
    Posts
    3
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Installing surveillance cams for a home owner. Could not find a spec on the instructions, wondering which is more common, A or B, any help would be appreciated.
  2. #2
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,595
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    My brother installed a Lorex system in his house and the cameras would not work with his pinning even though the pairs were correct on both ends. He called them and it turned out that he needed the proper termination protocol (568B) because the cameras would only work with the correct number of twists in the cable pairs. I would double check with the camera manufacturer or go with the 568B because that's a newer standard.
    Rob
  3. #3
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    4,125
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by infinity View Post
    If you believe that I have a bridge I want to sell you...
    568B is the most common (and oldest because it is an old WECO standard) here in the US. 568A is for compatibility with telecom especially when you punch one end down on a 66 block. Either can be used, it's just the green and orange pairs are swapped. Electricity is color blind.
    Infinity- GUARANTEED he screwed up the plugs when he crimped them on.
    -Hal
  4. #4
    Join Date
    Apr 2007
    Huntington Beach, CA (19 Hrs. 22 Min. from Winged Horses)
    Posts
    6,861
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by azebra View Post
    "B".
    i've never terminated in "A".... ever.
    ~New signature under construction.~
    ~~~~Please excuse the mess.~~~~
  5. #5
    Join Date
    Jun 2003
    Posts
    4,125
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well, you do want to use "A" when the rest of the facility is "A" and you are adding drops. That's about the only time I do it. Otherwise the next guy will be pulling his hair out.
    -Hal
  6. #6
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    6,042
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    As long as both ends are the same it doesnt matter tho 568B is more commercial and A residential, I never do A.
    I have a hard time believing that Lorex story because not every cable mfg twists the pairs the same, and all 4 pairs have different twist rates. I think Hal nailed it.
    The pinout for 568B is white/orange, orange/white, white/green, blue/white, white/blue, green/white, white/brown, brown/white.
    Also, never put on plugs in the field if you can help it - use jacks and patch cords - a beginner absolutely will hose up making the plugs.
  7. #7
    Join Date
    Jun 2003
    Posts
    4,125
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That is the absolute truth, I've been preaching that for a long time. I've been putting plugs on cables for probably 20 years so you would think I would have it down by now. But I still have to cut some off and re-do them not to mention trying to figure out which end is at fault.
    -Hal
  8. #8
    Join Date
    Nov 2009
    Opelousas, Louisiana
    Posts
    597
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by hbiss View Post
    -Hal
    Have you tried EZ PRO rj45 connectors? Just about mistake proof.
  9. #9
    Join Date
    Jul 2003
    New Jersey
    Posts
    26,595
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    -Hal
    Nope you're incorrect. I checked them personally with a pair tester and all of the cables tested good. We cut off the RJ45's and installed new ones using 568B and then the cameras worked.
    Rob
  10. #10
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    6,042
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Mgraw View Post
    RJ-45 is a very specific registered jack designation that is NOT the same as 568 8p8c. Yes, I have used the plugs that the wires pass thru so miswiring is virtually impossible. But a patch cord costs a buck and it takes me about 10 minutes to wire two 8p8c plug onto a piece of cable, which, btw, patch cords should be stranded and have the appropriate 8p8c stranded plug connector on it. Putting a 8p8c plug made for stranded wire onto solid wire (of which 99% of Catx wiring is) will guarantee problems in short order.
    https://en.wikipedia.org/wiki/RJ45
    "RJ45 (computers), an unkeyed 8-position, 8-contact modular plug (incorrectly referred to as RJ45)..."
    "Although commonly referred to as an RJ45 in the context of Ethernet and category 5 cables, it is incorrect to refer to a generic 8P8C connector as an RJ45.[8][9][10]"
Posting Permissions
  • You may not post replies
  • You may not edit your posts
