Results 1 to 5 of 5
Thread: Grounding in Barn
  1. #1
    Join Date
    Aug 2009
    Central NC
    Posts
    1,737
    Grounding in Barn
    Looking at a job for someone who just built a barn. He is planning to put about 10x15 foot concrete floors in 2 areas. My thinking is to carry a bare ground wire from main outdoor ground to closest floor, put a ground block on nearest post, then bury another from there to a ground block near 2nd location. When mesh is installed, carry a jumper to each from the nearest block.
    He also has 2 high faucets in barn. Metal riser pipes but plastic underground. I want to carry jumpers to each of them as well, just in case of any accidental contact with frayed drop cords, etc.
    Sound good? He will not be keeping animals in there, just equipment. But if he installs other significant runs of metals, I can have convenient means to ground them as well.
    Yes, I'll be happy to do a first class job for less than anyone else and take a dollar a week for 10 years.
  2. #2
    Join Date
    Jun 2003
    NE (9.1 miles @5.07 Degrees from Winged Horses)
    Posts
    9,036
    Quote Originally Posted by jmellc View Post
    Its overkill, and besides that, unneeded.
    Slab floors do not require bonding of any kind for this type of area. sounds like you have a couple slabs with no footings. How much of the metal risers are in contact with earth?
    Tom
    TBLO
  3. #3
    Join Date
    Dec 2006
    Eastern Oregon
    Posts
    3,433
    Barns will have a grounding electrode system just like any other structure.
    If it will contain livestock, then that opens an entirely different can of worms.
  4. #4
    Join Date
    Aug 2009
    Central NC
    Posts
    1,737
    Faucet risers come up about 3 feet. Risers are rigid metal, tie wired to metal stakes. UG piping is nonmetallic.
    Currently no plans to keep animals there, but this customer is generally full of surprises. He may change his mind next week or next year. I like to plan worst case with him. If I put in a grounding means now I am covered. Much easier than backtracking.
  5. #5
    Join Date
    Nov 2003
    Roanoke, VA.
    Posts
    4,310
    +1
    If he doesn't mind paying for it I'd do exactly what you are saying.
    Sometimes I don't know whether I'm the boxer or the bag.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
