Results 1 to 8 of 8
Thread: ARC Flash Labeling
  1. #1
    Join Date
    Apr 2014
    Huntsville, Alabama
    Posts
    29
    ARC Flash Labeling
    We have completed our AF study and moving towards the labeling phase. Our previous AF labels are more of a 'landscape' style rather than the latest AF studies 'portrait' style. We attempted to pull off the old labels and they will not cooperate i.e. they come off in shreds thus very time consuming! We thought about covering the older label with the new label however the older label will still be partially exposed. Any thoughts as to how we can cover or remove the older labels? Thanks
  2. #2
    Join Date
    Mar 2013
    Rutland, VT, USA
    Posts
    303
    Have you tried anything like a cleaner solution to help remove the previous labels? Rough up old label with sandpaper and spray, soak and remove?
    A plain white label material across the old label and then the new one on top of that?
    Black Sharpie marker on parts of old label still exposed after installing the new label?
  3. #3
    Join Date
    Apr 2014
    Huntsville, Alabama
    Posts
    29
    Thanks wbdvt for the response. I tried using WD40 (have been successful in the past) however these labels will not let go. I believe I am going to use 4" x 6" labels with 480VOLTS to cover them up.
  4. #4
    Join Date
    Jul 2006
    Posts
    7,322
    WD-40 is purposely NOT a good solvent, although it will penetrate well and loosen the bond in some cases. But sometimes to avoid having label adhesive attack enclosure paint, they use a glue that can be dissolved in alcohol. Try using denatured alcohol and really soak it for a few minutes. It evaporates really fast of course, so you have to soak a rag, then hold the rag up to the label for a couple of minutes sometimes. I've had a lot of success with that on electrical labels.
    __________________________________________________ ____________________________
    Many people are shocked when they discover I am not a good electrician...
  5. #5
    Join Date
    Apr 2014
    Huntsville, Alabama
    Posts
    29
    Thanks Jraef for the response
  6. #6
    Join Date
    Aug 2007
    Yachats Oregon
    Posts
    567
    Quote Originally Posted by fraymond View Post
    Use a heat gun to remove the old labels and then you can remove the old adhesive with "goof off" and/or waterless hand cleaner (with grit).
  7. #7
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    7,723
    Quote Originally Posted by stevenje View Post
    Above works well, use a long handled razor blade scraper, sometimes a citrus based cleaner will work.
    Moderator-Washington State
    Ancora Imparo
  8. #8
    Join Date
    Apr 2008
    Posts
    370
    I've used goo gone and it work well.
    https://googone.com/
Posting Permissions
  • You may not post replies
  • You may not edit your posts
