Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: What happened here?
  1. #21
    Join Date
    Jun 2006
    Ohio
    Posts
    21,385
    Quote Originally Posted by GoldDigger View Post
    I do not see the physics or thermodynamics to support that.
    Before it comes to a boil, why is water hotter at the top than it is at the bottom?
    I will have achieved my life's goal if I die with a smile on my face.
  2. #22
    Join Date
    Jun 2006
    Ohio
    Posts
    21,385
    Quote Originally Posted by Smart $ View Post
    And I know what you're going to say... that's convection... and it is. But at what point is there no movement in a solid?
  3. #23
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    18,587
    The answer is that in a solid there is vibrational motion, but no bulk motion except on a geological time scale. Which is not relevant here.
  4. #24
    Join Date
    Feb 2013
    India
    Posts
    2,257
    If heat source is at bottom, water at bottom is hotter than at top before it boils. Once it starts boiling, temperature is same throughout water. So the heat source must be at top of water surface.
  5. #25
    Join Date
    Jun 2006
    Ohio
    Posts
    21,385
    Quote Originally Posted by Sahib View Post
    I posted off the cuff. You are correct if heating the water faster from the bottom than gravity brings the hotter water to the top. My statement was more generalized, heat applied from all directions...
  6. #26
    Join Date
    Oct 2009
    Austin, TX, USA
    Posts
    8,681
    Because hotter water is less dense than cold water.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
