Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: Grounding rod question
  1. #1
    Join Date
    Nov 2003
    New Jersey
    Posts
    627
    I thought 8' gd. rod were supposed to be installed full depth in ground... my guess in this case, installer hit rock and stopped?? Any other comments would be appreciated.
    Attached Images Attached Images
    Tony Shupenko, PE
  2. #2
    Join Date
    Dec 2010
    Tennessee NEC:2008
    Posts
    4,418
    Could be a 10' rod and the installer left 2' out of the ground.
    Most likely the installer hit rock with an 8' rod and didn't have a blade for his "saws-all"!
    If you aim at nothing, you will hit it every time!
  3. #3
    Join Date
    Oct 2008
    Cincinnati, OH
    Posts
    85
    That close to the foundation he hit the footer.
  4. #4
    Join Date
    Jun 2016
    Tampa, FL, USA
    Posts
    1,165
    It's probably already cut to 3' and just poked into the ground. Did you try pulling on it?
  5. #5
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    4,621
    Quote Originally Posted by delfadelfa View Post
    I think you're right. It looks like it's bent some from hitting a solid object like a footer.
    Seriously doubt it's a 10' rod.
  6. #6
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,407
    This rod is an electrode for the service?
    Rob
  7. #7
    Join Date
    Nov 2003
    New Jersey
    Posts
    627
    Quote Originally Posted by infinity View Post
    Yes
    Tony Shupenko, PE
  8. #8
    Join Date
    Nov 2003
    New Jersey
    Posts
    627
    Quote Originally Posted by JFletcher View Post
    I agree.... footing would be closer to 6 feet below this point.
    Tony Shupenko, PE
  9. #9
    Join Date
    Nov 2003
    New Jersey
    Posts
    627
    Quote Originally Posted by Coppersmith View Post
    Some lateral wobble... though I did not pull on it.
    Tony Shupenko, PE
  10. #10
    Join Date
    Aug 2004
    Northern illinois
    Posts
    15,833
    if that is the worst thing you find, I would not be all that worried.
    Bob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
