Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Balancing conductors
  1. #11
    Join Date
    Jul 2005
    Tennessee
    Posts
    15,973
    Quote Originally Posted by kwired View Post
    That method doesn't "self bond" the two enclosures together in any way at all
    I do agree with the suggestion of "window" between enclosures butted against one another or a wireway between enclosures if you can't get a large enough raceway to fit.
    nope, but a short piece of wire can easily bond them. The terminal adapters provide a nice smooth transition in the panel with minimal intrusion. Might not be the best in your eyes but I have found it to be a great method.
    At my age, I'm accustomed to restaurants asking me to pay in advance, but now my bank has started sending me their calendar one month at a time.
  2. #12
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    37,101
    Quote Originally Posted by augie47 View Post
    Just trying to rough you up a little, no harm intended. I have done that and is a great method sometimes.
  3. #13
    You still have to have all your hots and neutrals together in the same hole.
    Sent from my SM-N900V using Tapatalk
  4. #14
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,363
    Quote Originally Posted by windingelectric View Post
    Yes you would need to have each set of phase conductors, neutral and EGC going through each corresponding nipple. That's why I would not use nipples if I wanted to keep the conductors grouped together by phase.
    Rob
  5. #15
    Join Date
    Jan 2012
    Ny Hudson valley
    Posts
    461
    Quote Originally Posted by infinity View Post
    How long are the nipples? If the panels are next to each other then I would just cut in a window or instead of nipples I would use a wireway between the two then you can orient the conductors anyway you want.
    8" nipples
    yea i like the window idea but I like having some space in between panels .
    wire wat would be nice but you know Forman fastest done usually trumps it .
    thanks for replys
  6. #16
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    37,101
    Quote Originally Posted by liquidtite View Post
    8" nipples
    thanks for replys
    Fastest done isn't good enough if there are code violations though.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
