Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Sauna
  1. #1
    Join Date
    Nov 2004
    WA
    Posts
    2,128
    Sauna
    can anyone point me to an NEC requirement for Sauna Heater At 240v (disconnect requirements)? Thank you!
    Lost for words
  2. #2
    Join Date
    Nov 2004
    WA
    Posts
    2,128
    Anyone?
    Lost for words
  3. #3
    Join Date
    Feb 2003
    Somewhere over the rainbow
    Posts
    3,279
    I could not find anything under "Sauna" but my guess would be 422.31(B) will apply. Also, follow the instruction manual.
    Lets see what others have to say.
    I will keep searching.
    Edward
    The only thing I know, is the progressive discovery of my ignorance
  4. #4
    Join Date
    Nov 2004
    WA
    Posts
    2,128
    Got the same! Per specs, its directly wired, no GFCI required. <<< Just surprised! TY!
    Lost for words
  5. #5
    Join Date
    Feb 2003
    Posts
    3,279
    Quote Originally Posted by resistance View Post
    But your question was disconnect related not GFCI.
    If 422.31(b) applies then a disconnect is required.
    Edward
  6. #6
    Join Date
    Nov 2004
    WA
    Posts
    2,128
    I was on the topic of the disco (Thats why I said "got the same"). My initial—I was hoping—would cover all basis related to the disconnect (Meaning: I figured someone would bring up the disco being within sight or other related topics on the disco). Once I seen that we seen the same, The GFCI was just an added convo..
    Lost for words
  7. #7
    Join Date
    Nov 2004
    WA
    Posts
    2,128
    TY!
    Lost for words
  8. #8
    Join Date
    May 2005
    Tacoma, WA
    Posts
    233
    If disconnect is not within site, a lockout on breaker will suffice.
  9. #9
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    37,084
    As far as GFCI protection goes there is no general increased risk of electric shock to users of the sauna like there is for swimming pools or spas. You are usually in a small room or other space that has a heater with or without added humidity. No different then having a furnace in your house with a humidifier but you usually don't turn the set point as high.
  10. #10
    Join Date
    Feb 2016
    Illinois
    Posts
    901
    My sauna heater is designed to have water poured onto it in order to produce steam. It is in my finished basement and has a bare concrete floor. The installation instructions did not mention GFCI and I don't believe GFCI is required by code, but I could see one making a case for including it.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
