Results 1 to 8 of 8
Thread: What is the Maximum number of sockets on a branch circuit of 220 V /20 Amp
  1. #1
    Does NEC puts any restriction on the maximum number of sockets or am I right in calculating as follows = 220V X 20/180 VA?
  2. #2
    Join Date
    Jul 2007
    Iowegia
    Posts
    17,889
    Dwelling or not?
  3. #3
    Dwelling
  4. #4
    Join Date
    Jul 2015
    Wilmington, NC USA
    Posts
    282
    Is this for a dwelling in the USA or somewhere else in the world?
  5. #5
    Outside the USA
  6. #6
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    5,438
    240V 20A receptacles are usually for dedicated equipment here (US), like PTAC (air conditioning and heat) units, and there would typically be just one per circuit. On 120V circuits, there is no NEC limitation of # of receptacles per circuit - not sure on 220/240V tho in an overseas installation.
  7. #7
    Join Date
    Jul 2015
    Wilmington, NC USA
    Posts
    282
    Quote Originally Posted by Anwar Pasha View Post
    Outside the USA
    Does that mean the 220V receptacles are convenience outlets (like our 120V receptacles)? If so, see the above post by JFletcher.
  8. #8
    Thanks everybody for your response and support
Posting Permissions
  • You may not post replies
  • You may not edit your posts
