Results 1 to 4 of 4
Thread: Fire alarm smoke detectors in multi level ceilings
  1. #1
    Join Date
    Dec 2015
    Ankara, Turkey
    Posts
    29
    Hi!
    We're designing a lobby where the ceiling is multi level. There are pools for hidden lights. The lowest level of ceiling is at +4.55 AFF. Then there is a higher area in the middle which is at +8.30 AFF.
    The detectors on the lowest level of the ceiling do provide the required coverage. Do I then need to install smoke detectors on the higher levels (+8.30 AFF) of the ceilings?
    I have attached a reference plan and a section so it is easier to understand.
    Thanks all!
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	18178   Click image for larger version.
ID:	18179   Click image for larger version.
  2. #2
    Join Date
    May 2012
    Amissville, Virginia USA
    Posts
    202
    Quote Originally Posted by Gilf View Post
    Hi!
    Thanks all!
    Where is the smoke most likely to go? Hot air rises. Try to get installation instructions for the brand you are using. They have alot of good information that will help you.
    Sent from my SM-T350 using Tapatalk
  3. #3
    Join Date
    Jun 2003
    Posts
    6,683
    NFPA 72 has lots of info. about installing detectors on ceilings with various levels, pockets, beams, headers, etc.
  4. #4
    Join Date
    Oct 2007
    New Jersey
    Posts
    4,586
    Hi!
    Thanks all!
    I assume the ceiling heights are in meters? Just to clarify for us metrically-challenged Americans.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
