Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Arc faults tripping after wiring pump
  1. #11
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    37,098
    Chuck conductors in a drill and turn them until they are so tight that you trip on short circuit/ground fault because you damaged the insulation.
    It will no longer be an AFCI issue that is causing tripping.
  2. #12
    Join Date
    May 2014
    AZ
    Posts
    2,324
    twisted pair is a crude ez way to help keep Rf noise out. if a VFD is superimposing Rf noise directly onto the wiring the twisted pair may help slightly.
    other devices tripping sounds to me like a resonant freq. a scope with FFT will help identify the noise.
    some wraps of the wires to form small inductor will also help. w/o proper testing the best you get is try and see.
  3. #13
    Join Date
    May 2014
    AZ
    Posts
    2,324
    any update?
  4. #14
    Join Date
    Feb 2003
    New Jersey
    Posts
    3,656
    I've never heard of the tight twisting method of correcting this problem but it's good advice if it actually works. First thing I would do is remove the pump and see if that corrects the problem. If not, I would also check to see if there is a ham radio operator in the area. There are you-tube videos on this on the internet. If you key up a mic and if your antenna is fairly close to the breaker panel (could be a neighbor) it will trip all the AFCI breakers.
    Had a situation like this in a condo Bldg. In Jersey City, NJ with GFCI breakers. Any time the guards on duty would make their rounds and they reported in via Wilkie-talkie it would trip all the GFCI breakers in the panel that contained wiring for ice melt systems.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
