Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: No fossil fuel - carbon monoxide alarm needed?
  1. #1
    Join Date
    Feb 2006
    Jersey
    Posts
    2,232
    In Jersey. (And I guess elsewhere)?
    If a condo (or house) is ALL electric, would carbon monoxide detectors be required ?
    Thank you.
    " I'm at a crucial part of my painting "...........Monika Danneman
  2. #2
    Join Date
    May 2012
    Amissville, Virginia USA
    Posts
    202
    If you have an attached garage.
    Sent from my SM-T350 using Tapatalk
  3. #3
    Join Date
    Nov 2016
    US
    Posts
    100
    N.J. Stat. Ann. § 55:13B-6.1 – Rooming and Boarding Houses
    Requires every unit of a rooming or boarding house be equipped with one or more carbon monoxide sensor devices unless it is determined that no potential carbon monoxide hazard exists for that unit.
    Taken from National Counsel of State legislatures.
    Sent from my VS987 using Tapatalk
  4. #4
    Join Date
    Feb 2006
    Jersey
    Posts
    2,232
    Ok. This is a condo. No garage.
    No chance of CO. unless someone hooked up a hose to a car and dragged it to the third floor.
    Thank you both for the info. Appreciated.
  5. #5
    Join Date
    Jul 2013
    Arcata, CA
    Posts
    395
    Until someone brings in a charcoal briquette barbecue.
  6. #6
    Join Date
    Jun 2015
    texas
    Posts
    1,697
    Quote Originally Posted by Barbqranch View Post
    Or until the power goes out in the middle of a brutal NJ winter and someone needs to crank up the kerosene heater......
  7. #7
    Join Date
    Mar 2016
    The Motor City, Michigan USA
    Posts
    708
    Would the little bit of money saved really be worth it?
  8. #8
    Join Date
    Apr 2008
    Ann Arbor, Michigan
    Posts
    6,838
    170810-2355 EDT
    Most homes contain a lot of organic materials. Organic materials contain carbon. Thus, burning of organic materials may produce CO and/or CO2.
    How do most CO detectors work, and are they selective to only CO? A heated resistive component (a thermistor for example) can detect CO or any combustable gas.
    I don't know what commercial detectors use.
  9. #9
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,233
    Commercial detectors have a finite lifetime from opening the package, which suggests that there is a specific chemical reagent that reacts with CO.
  10. #10
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    36,715
    Quote Originally Posted by gar View Post
    170810-2355 EDT
    But those organic materials are not pure carbon - they will give off other gases and particles if they burn and a smoke alarm will detect that. The primary reason for CO detectors is to detect malfunction in ventilation of gas burning appliances where they don't give off other particles during the combustion process. If you don't have such appliances there is not much need to detect this gas.
    Car in the garage - if you don't have ventilation you are going to set off such detectors frequently I would think. I also think opening the overhead door is going to provide sufficient ventilation - bottom line don't run the car with the door closed. If you were trying to kill yourself by running the car in a closed garage then you will just be upset when the CO alarm interrupts your process
Posting Permissions
  • You may not post replies
  • You may not edit your posts
