Page 5 of 5 FirstFirst ... 345
Results 41 to 43 of 43
Thread: VFD Application?
  1. #41
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    33,421
    Quote Originally Posted by Ingenieur View Post
    so no speed change is required?
    normally 2 belts at ~50% load and full speed (each a different material)
    or when 1 is removed from service
    1 belt at 100% load and full speed (alternating product at twice the density)
    seems like a VFD is not required?
    with vfd's
    under normal conditions you could slow the belt down and load it to 100%
    no advantage
    again
    Power = work/time = weight x distance / time
    if time goes up, ie, slower at 1/2 speed
    and weight goes up, twice the material
    they offset, the P is the same
    work does increase but so does the time
    time needed to do the same work decreases, right? I'm sure you know this but think it just came out wrong.
    The only way it is worth installing the drive is if there is significant enough change of inefficiencies, otherwise the same work is being done.
  2. #42
    Join Date
    Jan 2016
    PA
    Posts
    4,010
    Quote Originally Posted by kwired View Post
    if you slow the belt down, time increases
    MORE work is being done, more weight (double the load) over the same distance
    offsetting, so same power used
  3. #43
    Join Date
    Sep 2008
    UK
    Posts
    10,200
    Nor advantageous.
    Si hoc legere scis nimium eruditionis habes.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
