Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Masonry extension ring
  1. #1
    Join Date
    Feb 2005
    New England
    Posts
    1,063
    Looking for a masonry extension ring. Single gang 1.5 inch deep....
    Best I could come up with is a 1.5 inch deep handy box extension ring
    Hubbell-Raco 653 1-1/2-Inch Deep Handy Box Extension, Welded
    Feedback is appreciated
  2. #2
    Join Date
    Mar 2006
    Northern Indiana
    Posts
    65
  3. #3
    Join Date
    Feb 2016
    Illinois
    Posts
    685
    I hope those prices are for a case of 10 (or more).
  4. #4
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    18,757
    These seem to be 2-1/2 and 3-1/2 inch. OP asked for 1-1/2.
  5. #5
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    4,605
    Quote Originally Posted by retirede View Post
    Given that retail for the part # you gave is over $5 ea on Amazon, and $12 on Platt, they probably are not case prices. What's wrong with the 653?
    You'd probably have more options if you were looking for mudrings for 2 gang boxes. If you can't get all the way to the face of the block, you can use these as well:
    http://www.homedepot.com/p/Electrica...E1-2/202708650
    with long screws thru the device to reach the threads of the recessed box.
    I think they are closer to $2 ea in BB stores.
  6. #6
    Join Date
    Feb 2005
    New England
    Posts
    1,063
    Quote Originally Posted by GoldDigger View Post
    Yep 1-1/2 single gang.
    I have never tried to put a handy box extension ring on a masonry box... I wonder if it would work.... Just duct tape it to keep cement out?
  7. #7
    Join Date
    Jun 2016
    Tampa, FL, USA
    Posts
    1,160
    Quote Originally Posted by JJWalecka View Post
    I've never used a masonry extension ring. What is the purpose of it? If it's to bring the face of a box buried inside a block to the surface, wouldn't a mud ring work? That's what I use for that purpose. Of course, you have to use 4x4 boxes inside the block. Sounds like maybe you are using something else.
  8. #8
    Join Date
    Dec 2010
    Tennessee NEC:2008
    Posts
    4,406
    Quote Originally Posted by JFletcher View Post
    If you read in the specs for the linked boxes it shows "package of 5".
    So that is not that bad, around $4 per box.
    If you aim at nothing, you will hit it every time!
  9. #9
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    4,605
    Quote Originally Posted by Little Bill View Post
    $4 for that plastic extension is twice what an adjustable single gang box would have cost in the first place. Zip it flush with the wall, forget using long screws and those "oops, I messed up" extensions.
    "Just duct tape it to keep cement out?"
    I was thinking this was for an existing install rather than new. I dunno if there is anything better...dont see why duct tape wouldnt work tho.
  10. #10
    Join Date
    Feb 2005
    New England
    Posts
    1,063
    Quote Originally Posted by Coppersmith View Post
    A single gang masonry box is installed in a kick plate of a stairwell...it is sitting back and 1-3/4 or there of...I need being the box out flush with block. Thinking a handy box extension ring might work.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
