Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: can thermal protectors
  1. #1
    Whats the reason for the neutral? Wouldn't a simple bi-metal switch work just as well?
    Attached Images Attached Images
  2. #2
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    4,244
    Line/load markings? I see that overload as just making/breaking one conductor, not hot and neutral with a ground wire.
  3. #3
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    8,614
    If that is for a single phase motor, depending on the way the motor was wound, one lead would protect the running winding and one would protect the starting winding and the third would be the common.
    Once in a while you get shown the light
    In the strangest of places if you look at it right. Robert Hunter
  4. #4
    Join Date
    Nov 2009
    Opelousas, Louisiana
    Posts
    503
    There is a heater inside the thermal overload which creates enough heat to cause the overload to trip if the overload is surrounded by insulation.
  5. #5
    Join Date
    Jul 2003
    New Jersey
    Posts
    23,551
    Sounds like a recessed lighting thermal to me. Are the conductors in the photo are black, white and blue?
    Rob
  6. #6
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    33,098
    Quote Originally Posted by Mgraw View Post
  7. #7
    Well that explains why the neutral is there, but are you saying the ambient air, when reaching a setpoint, causes the heater to come on thus tripping the overload or
    that the heater is on all the time and when the ambient air temp is added the overload then trips?
    Still don't understand why a simple switch wouldn't do the same thing
  8. #8
    Join Date
    Nov 2009
    Posts
    503
    They are used to prevent insulation being wrapped around non ic rated cans. The heater is always on.
  9. #9
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    9,290
    All the while we look for ways to save every milliwatt of electricity.....
    Cheers and Stay Safe,
    Marky the Sparky
  10. #10
    Join Date
    Feb 2009
    Posts
    8,614
    I gotta get my eyes checked. I did not see the word "can" in the title of this thread the first time I looked at it.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
