Results 1 to 5 of 5
Thread: Lighting Design
  1. #1
    Join Date
    Aug 2017
    Qatar
    Posts
    4
    Lighting Design
    I would like to know the basic formula for designing a indoor and outdoor lights. Let's suppose i am going to light a room with an area of 50m2(10*5), so the formula what i know is Illumination = Area*Lumen/Watts*Total Wattage*Light depreciation factor*Maintenance factor. But how to add height into it i mean what's the exact method or formula when considering height as well!! confused :/ Please help!!
  2. #2
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    3,651
    That would make my head hurt.
    All manufacturers have data, design guides and photometrics for their products.
    -Hal
  3. #3
    Join Date
    Feb 2007
    USA
    Posts
    5,687
    I sort of get where you are going but I am not clear as to what you wish to include as a feature in your design.
    as far as ceiling height you need to look at the inverse square law. :
    "the power of the light will be inversely proportional to the square of the distance. So if we take a distance of 2 and square it, we get 4, the inverse of which would be 1/4 or rather, a quarter of the original power - not half."
    from Wikipedia:
    Mathematically formulated:
    It can also be mathematically expressed as:
    or as a constant quantity
    Are you looking for efficiency?
    Long life?
    I would not think that illumination would include all those things you list unless you are trying to achieve a certain illumination vs overall efficiency as well as life of the lamp.
    Things to consider:
    Lumens per watt
    Lumen maintenance - any light source output is diminished over life of the lamp.
    cost of replacement
  4. #4
    Join Date
    Feb 2003
    New York, 40.7514,-73.9925
    Posts
    4,523
    For simple calculations and a sample fixture data sheet you want to use, Google "zonal cavity lighting calculator'
    Ron
  5. #5
    Join Date
    Jun 2003
    Posts
    6,892
    Quote Originally Posted by ron View Post
    And if you really want to know the formulas, here they are:
    http://aesl.hanyang.ac.kr/class/are1...o%20method.pdf
Posting Permissions
  • You may not post replies
  • You may not edit your posts
