Results 1 to 4 of 4
Thread: Bonding permanently installed swimming pools AKA above ground swimming pools
  1. #1
    Join Date
    Aug 2017
    Gloucester, VA, USA
    Posts
    1
    We have recently installed electrical systems for a few above ground swimming pools. We are coming across some that have 4-#8 bare copper ground pigtails for meeting the bonding requirements. In this case, can we use split bolts to bond the 4 points of the pool or must we use irreversible crimps?
  2. #2
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,162
    You can use split bolts.
    680.26(B)
    If you go and decide to dance with a gorilla the dance ain't over till the gorilla decides it's over.
  3. #3
    Join Date
    Dec 2010
    Tennessee NEC:2008
    Posts
    4,418
    If we can't use split bolts I'm in trouble a 1000 times over!
    If you aim at nothing, you will hit it every time!
  4. #4
    Join Date
    Jun 2012
    NW Ohio
    Posts
    950
    May have to check if your split bolts are listed for direct burial if it is the case in your situation having them buried.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
