Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: Closet Fire Rating
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    1,852
    Closet Fire Rating
    Have a tele/data closet that has sheetrock. Is there any way this closet could be a 2 hour rated closet if it's sheetrocked? Thought it had to be ONLY masonary/concrete exposed walls to be 2 hour rated. Thanks.
  2. #2
    Join Date
    Oct 2007
    New Jersey
    Posts
    5,227
    Quote Originally Posted by mstrlucky74 View Post
    The short answer is "yes". See here for an installation guide from USG. Basically requires double 5/8" board on each side of the stud.
  3. #3
    Join Date
    Sep 2012
    NJ
    Posts
    1,852
    Quote Originally Posted by gadfly56 View Post
    thanks
  4. #4
    Join Date
    Sep 2014
    Nashville, TN
    Posts
    135
    What about the door/frame? If they don't have a 2-hour label, then the wouldn't be rated.
  5. #5
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,383
    4 layers of 5/8" Sheetrock is pretty standard for the 2 hour wall rating.
    Rob
  6. #6
    Join Date
    Oct 2007
    New Jersey
    Posts
    5,227
    Quote Originally Posted by GrayHair View Post
    Oddly enough, openings in a 2-hour rated room are allowed to be 1-1/2 rated.
  7. #7
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    4,617
    Yep. Adjoining walls in hotels are often rated 2 hour, and iirc it doesnt even require double 5/8" on both sides.
    If you are worried about penetrating it, you can get pre-made sleeve kits from STI that have everything you need and a 2 hr rating if installed correctly.
  8. #8
    Join Date
    Apr 2006
    Simi Valley, CA
    Posts
    8,242
    Quote Originally Posted by JFletcher View Post
    Hotels do not fall under the IRC.
    I can build anything you want if you draw a picture of it on the back of a big enough check.
    There's no substitute for hard work....but that doesn't mean I'm going to give up trying to find one.
    John Childress
    Electrical Inspector
    IAEI / CEI / C10
    Certified Electrical Inspector
  9. #9
    Join Date
    Oct 2007
    New Jersey
    Posts
    5,227
    Quote Originally Posted by cowboyjwc View Post
    That's I I R C not I R C. Time for new glasses!
  10. #10
    Join Date
    Apr 2006
    Simi Valley, CA
    Posts
    8,242
    ok I give what's the IIRC?
    John Childress
    IAEI / CEI / C10
Posting Permissions
  • You may not post replies
  • You may not edit your posts
