Results 1 to 2 of 2
Thread: converting hardwired to plug-in - GFCI solution
  1. #1
    Join Date
    Aug 2017
    texas
    Posts
    1
    I bought some hard-wired sconces which must be converted to plug-ins. Problem is their ground wires can not be used (Lutron's plug-in lamp dimmers are only 2-prong). Will installing GFCI outlets be a safe way to get around the grounding problem? I read the NEC allows this. Sconces are brushed nickel which I looked up isn't very high on the conductivity chart anyway. Thanks anybody.
  2. #2
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    18,772
    Quote Originally Posted by ralf View Post
    Fixtures that are meant to be used without a ground wire (standard table and floor lamps) have their insulation specifically tested for that use.
    Hardwired fixtures, on the other hand, may rely on the ground wire for extra safety to pass the tests.
    There is no way to do what you want safely, even with an electrician involved, although a GFCI protected circuit would improve things.
    That said,
    I am closing this thread, in accordance with the Forum Rules.
    This site is designed for:
    • Contractors
    • Electricians
    • Engineers
    • Inspectors
    • Instructors
    • Other electrically related individuals
    * This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
    If you feel this action to be in error, feel free to contact me via PM to explain.
    A reminder to all members, if you see a questionable post, feel free to report it by clicking the button at the bottom left corner of the post.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
