Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
Thread: Compression Splices
  1. #11
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,573
    Quote Originally Posted by mstrlucky74 View Post
    No tools? How is it done?
    That white part in the pic gets pulled out and the black part collapses.
    If you go and decide to dance with a gorilla the dance ain't over till the gorilla decides it's over.
  2. #12
    Join Date
    Sep 2012
    NJ
    Posts
    2,029
    Quote Originally Posted by ActionDave View Post
    Neat....thanks.
  3. #13
    Join Date
    Aug 2004
    Las Vegas
    Posts
    441
    Quote Originally Posted by goldstar View Post
    you can get one of these for about $150:
    https://www.delcity.net/store/V!Crim...-Tool/p_800107
    $150. Too much money.
    Try this hyralic crimper for $40:
    https://www.amazon.com/Best-Choice-P.../dp/B00CUQ042Q
    The catch is they are both sold as battery cable crimpers. The one I posted is 10 ton.
    Think the dies are metric sizes.
    For only $20 you got your hammer crimper:
    https://www.amazon.com/TEMCo-Hammer-...9SZ2RA8F3N00V2
    Good for up to 4/0.
    LOL
  4. #14
    Join Date
    Aug 2004
    Northern illinois
    Posts
    16,801
    Quote Originally Posted by infinity View Post
    At Mrluckys labor rate two journeymen using that battery crimper for two or three days will pay for itself over a manual crimper.
    We bought one and used it so much it burned up the motor and so we had to buy another one.
    I figure we probably broke even after crimping a few hundred 1/0 cables.
    We have one for doing smaller terminals as well (I think it goes up to #8 wire). faster and a better crimp than can be done by hand, plus no carpal tunnel syndrome.
    Bob
  5. #15
    Join Date
    Sep 2012
    NJ
    Posts
    2,029
    We use Burndy with battery operated crimpers. Yes they take a little longer because you need to crimp both sides of the splice (anywhere from 2-5 per side) and then install a cold shrink. A Polaris type splice you just strip, insert, and torque. Done.
    Approx how long would you say it would take to install a #600 cold shrink? 15 minutes tops?
  6. #16
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,375
    Unless you forget to put it on before you crimp less than 5 minutes.
    Rob
  7. #17
    Join Date
    Sep 2012
    NJ
    Posts
    2,029
  8. #18
    Join Date
    Feb 2009
    Posts
    9,573
    Neat....thanks.
    You really wish you weren't stuck in an office don't you?
  9. #19
    Join Date
    Sep 2012
    NJ
    Posts
    2,029
    lol... 100%!!!
  10. #20
    Join Date
    Apr 2007
    Huntington Beach, CA (19 Hrs. 22 Min. from Winged Horses)
    Posts
    6,585
    Quote Originally Posted by active1 View Post
    a lot of jobs are specifying witness marks on the crimps to verify UL approval.
    the correctly sized die, when swaged, will leave a die mark raised in the swage mark.
    these critters are the reason why. not UL listed termination.
    ~New signature under construction.~
    ~~~~Please excuse the mess.~~~~
Posting Permissions
  • You may not post replies
  • You may not edit your posts
