Results 1 to 7 of 7
Thread: Current limiters for track lighting
  1. #1
    Join Date
    Sep 2012
    United States
    Posts
    25
    The current limiters you can buy as breakers (with their Din rail mounting) in their own panel appear to be nothing more than breakers, what makes these sacrosanct VS a standard breaker with the same amperage? This is per use for our states compliance with the model energy code to limit the power to track lighting runs. They typically are very small amps like 1,2,3,5, etc.
  2. #2
    Join Date
    Apr 2008
    Ann Arbor, Michigan
    Posts
    6,577
    170831-0642 EDT
    Is this really a current limiter (something like a constant current source, I doubt it), or is it just a low current circuit breaker that trips open on overload, or a recycling over current device?
    What happens upon an overload?
  3. #3
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,374
    What energy code requires this?
    Rob
  4. #4
    Join Date
    Jun 2010
    Posts
    1,928
    I am curious as to how they work.
    http://forums.mikeholt.com/showthread.php?t=127686
    It sounds like a self activating dimmer that dims down to the load I-rms to the rating. Kind of like "thermal management" found in LED ballasts that activates dimming to hold the case temperature or LED head temperature to prevent ballast or LED fryout.
  5. #5
    Join Date
    Nov 2010
    Fort Collins, Colorado
    Posts
    2,537
    Quote Originally Posted by SparkyRules View Post
    Good question. Since these are an energy code requirement as opposed to an NEC requirement I'm not sure who dictates how current limiting is done. It would seem to me that unless the energy code specifies how or to be listed for the purpose then you could use a DIN breaker of the appropriate value. The NEC would just see this as a supplementary overcurrent device. That said, isn't it just as easy to just use the packaged devices sold for this purpose?
  6. #6
    Join Date
    Jun 2010
    Posts
    1,928
    http://www.cooperindustries.com/cont...8013en-bro.pdf
    Ok... so just a tiny circuit breaker. It's probably the LED industry lobbyists.
  7. #7
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    18,772
    Quote Originally Posted by infinity View Post
    CA, among others.
    The code specifies maximum lighting watts (not just lumens) for a given area and usage.
    Since you can add heads to track lighting after inspection the current limiters are there to set a hard maximum on the watts you can install on particular sets of track.
    So that what the inspector sees and Fullthrotl certifies is what stays in use.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
