Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: 2 Seprate Conduit Runs?
  1. #21
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    9,487
    Quote Originally Posted by mstrlucky74 View Post
    Always curious about this. Would you guys actually run 2 separate conduits from the panels to the equipment a shown or one pipe with all three circuits to a box near the equipment then branch from there. What the determining factor as to which way it would be done? Thanks.
    If the prints specify separate conduits and no one has gained approval to do it differently, that's what we would run. There may be a reason the designer wanted the condensate pump separate from the A/C unit. Maybe it's a spec from the A/C manufacturer. Who knows? Bid it like it shows, and it should get run like that. If you have an issue with the design, a call to the person that drew it up may be in order. Asking how people here would do it and making changes based upon that information alone may get you in a jam.
    Cheers and Stay Safe,
    Marky the Sparky
  2. #22
    Join Date
    Jul 2005
    Posts
    775
    Quote Originally Posted by petersonra View Post
    I was referring to the idea of running only one conduit instead of the two shown on the drawing.
    Did you not read this for the third time?
    It was clarified ...they are coming from same panel. Panel schedule indicates so as well.
  3. #23
    Join Date
    Aug 2004
    Northern illinois
    Posts
    15,754
    Quote Originally Posted by cdslotz View Post
    they are coming from the same panel. the drawing still shows two separate conduits.
    Bob
  4. #24
    Join Date
    Jul 2005
    Posts
    775
    forth time....smh
Posting Permissions
  • You may not post replies
  • You may not edit your posts
