Results 1 to 4 of 4
Thread: 125% of largest motor
  1. #1
    Join Date
    Jul 2005
    Tennessee
    Posts
    15,472
    In the past few months i have completed two courses on Residential Load Calculations. Although both contained much of the same info, I noted one emphasized a step adding 125% of the largest motor load to the final calculation whereas it is not mentioned in the other.
    In looking at MH calculation tools I don't see that 125% figure. Has anyone noted form testing if such a number should be included when calculating load ?
    At my age, I'm accustomed to restaurants asking me to pay in advance, but now my bank has started sending me their calendar one month at a time.
  2. #2
    Join Date
    Dec 2010
    Posts
    1,342
    I have seen it as a requirement from a number of utility companies.
    The more they overthink the plumbing, the easier it is to stop up the drain
  3. #3
    Join Date
    Jun 2006
    Ohio
    Posts
    21,385
    Quote Originally Posted by augie47 View Post
    The extra 25% for the largest motor is actually required under standard calculation. It seems many, including AHJ's, overlook it in residential calculations... especially if the motor is part of an appliance.
    I will have achieved my life's goal if I die with a smile on my face.
  4. #4
    Join Date
    Jan 2009
    Maryland
    Posts
    13,135
    Many times the HVAC contains the largest motor and when it is calculated at 125% and 220.50/430.24 is satisfied.
    Problem is that it is not always stated clearly by authors.
    "Electricity is really just organized lightning." George Carlin
    Derek
Posting Permissions
  • You may not post replies
  • You may not edit your posts
