View Poll Results: Would you rewire it?
Voters
19. You may not vote on this poll
  • Yes, I would rewire it to a lighting circuit.
    3 15.79%
  • No, I would reconnect to the kitchen appliance circuit.
    16 84.21%
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 25
Thread: Would you rewire it?
  1. #11
    Join Date
    Jul 2007
    Iowegia
    Posts
    17,696
    Quote Originally Posted by tortuga View Post
    By "other outlets" they mean lighting outlets.
    I say they mean 'outlets in other areas'. Keep in mind..... back then it was common for lighting outlets to be receptacles...... even in the ceilings.
    Quote Originally Posted by user 100 View Post
    210.52(B)(2)
    That said, If I were the op, I wouldn't change a thing.
    Let me know where 210.52(B)(2) is in the 1940 NEC.
  2. #12
    Join Date
    Nov 2003
    Roanoke, VA.
    Posts
    4,313
    Quote Originally Posted by roger View Post
    I would leave it as is.
    Roger
    +1
    Roger that.
    Sometimes I don't know whether I'm the boxer or the bag.
  3. #13
    Join Date
    Jul 2005
    (44.057116, -123.103394)
    Posts
    282
    Quote Originally Posted by 480sparky View Post
    Since the 1940 NEC defined an "outlet" the same as the 2017 NEC and like today they defined a receptacle outlet as " An outlet equipped with one or more receptacles, not of the screw shell type"
    And they defined a "lighting outlet" as "An outlet intended for the direct connection of a lampholder, a lighting fixture or a pandant cord terminating in a lamp holder"
    We can be sure that even in a old house receptacle outlets in the kitchen, laundry, pantry, dining room and breakfast room should be on a 20A circuit not sharing with a lighting outlet.
  4. #14
    Join Date
    Jun 2015
    texas
    Posts
    1,626
    But the old rule mentions "receptacle outlets" and the circuits that serve those in the areas spec'd by the op.
    Its not, but that is beside the point- the receptacle is in part of an area specified under the old code, clearly not allowed then.
    The 2 sabc per dwelling rule appeared on the scene in the 1959 NEC (220/3/B) and contained similar language to the 1940 code w/ respect to mixing lighting outlets and receptacle outlets in the areas the op was talking about.
  5. #15
    Join Date
    Jul 2007
    Iowegia
    Posts
    17,696
    What the actual intention was I doubt anyone here is old enough to say one way or the other.
    As it stands, the language is ambiguous. Just like parts of the Code today.
  6. #16
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    18,603
    I don't see it as ambiguous at all.
    If it supplies receptacle outlets in the listed areas it shall not supply other outlets. That means on non-receptacle outlets anywhere and no receptacle outlets in other non-listed areas. If the receptacle outlets happen to supply lighting, I do not see a problem. If the lighting is hard wired, then it would be prohibited.
    There are easy ways to specifically state any of the alternatives you suggested, so I am willing to accept the perfectly clear common English sentence structure as meaning exactly what it says.
    What I would do for my own house is not necessarily what I would take responsibility for at a customer's house.
  7. #17
    Join Date
    Jul 2005
    Posts
    282
    Well thanks everyone for the votes I moved the switch and kept it on the kitchen appliance circuit for now. I did figure out a way to add a tail to the new switch box so I can put it on a proper lighting circuit some day without having to rip the back splash open.
  8. #18
    Join Date
    Jul 2007
    Iowegia
    Posts
    17,696
    Quote Originally Posted by GoldDigger View Post
    I don't see it as ambiguous at all. ..........
    Then we'll have to agree to disagree.
  9. #19
    Join Date
    Feb 2003
    Minnesota
    Posts
    6,606
    I am looking at paragraph 2109 1940 NEC "Receptacle Circuits in Dwellings. In dwelling occupancies, branch circuits which supply receptacle outlets in the kitchen, laundry, pantry, dining room and breakfast room shall not supply other outlets and such circuits shall have conductors not smaller than No. 12"
    The 1940 NEC Definitions make it clear that, for the purposes of this quoted rule, only Receptacle Outlets are allowed . . . That is quite unambiguous.
    Another Al in Minnesota
  10. #20
    Join Date
    Feb 2003
    Minnesota
    Posts
    6,606
Posting Permissions
  • You may not post replies
  • You may not edit your posts
