Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Two circuits in a dual gang box?
  1. #11
    Join Date
    Feb 2003
    Fl
    Posts
    17,140
    Quote Originally Posted by Smart $ View Post
    Quit being so cryptic.
    What 210.7 says is that the circuits must have simultaneous disconnecting means at the circuits' origin. May as well make it a MWBC... but otherwise GD is correct since he said not an MWBC.
    Well the first sentence is what I was addressing with the article section.
    I believe that you cannot have two circuits on one device yoke if the result would be 240 or more line to line
    Roger
    Join Date
    Aug 2017
    Los Angeles CA
    Posts
    154
    Quote Originally Posted by jumper View Post
    If I see have 3 black wires, 3 white wires, and 3 green-how many circuits are present?
    It all depends on how they are connected together. But with only three wires one would have to assume one is a source and the two other are loads.
  3. #13
    Join Date
    Jan 2007
    Posts
    3,525
    0,1,2,3,4,......... oh the possibilities......
    JAP>
  4. #14
    Join Date
    Jun 2006
    Ohio
    Posts
    21,385
    Quote Originally Posted by roger View Post
    Roger
    Okay.
    You did bring up earlier 404.8 regarding switch to switch and other devices with respect to a switch, over 300 volts requiring identified barrier separation. He may have been thinking about that. IDK
    I will have achieved my life's goal if I die with a smile on my face.
  5. #15
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,256
    Quote Originally Posted by Andy Delle View Post
    Not if it is a receptacle box rather than just a junction box or switch box.
  6. #16
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    5,438
    Can a dual (or larger) gang box have two different circuits feed it? Not necessarily a MWBC, just two different circuits. As I see it this is a safety issues in that somebody kills one of the circuits by checking the light or other load yet there still is another hot feed inside the box?
    Yes. There was a thread here recently re: using one box for 4160V and 208V (hypothetical install). I dont remember the outcome, tho iirc that is allowed, however an incredibly bad idea imho.
    eta: here's the thread:
    http://forums.mikeholt.com/showthread.php?t=185655
  7. #17
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    14,196
    Quote Originally Posted by jap View Post
    JAP>
    "Electricity is really just organized lightning." George Carlin
    Derek
  8. #18
    Join Date
    Dec 2010
    Tennessee NEC:2008
    Posts
    4,617
    Quote Originally Posted by ActionDave View Post
    If you look inside a box and can't tell if there are multiple circuits in there then you have no business being in there.
    In normal/correct wiring, yes. However I have seen two or more circuits in a box and they tied all the neutrals together!
    If you aim at nothing, you will hit it every time!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
