Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 40
Thread: Electric Baseboard Heat Calculation
  1. #21
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,707
    Quote Originally Posted by drcampbell View Post
    That would be the worst selection possible. This basement will need heat only on the coldest days of the year, during which a mini split (or any other heat pump) will switch over to resistance heat.
    Only if you have a lot of cold days where it must depend on the back up heat, one day here and there may not be that bad.
  2. #22
    Join Date
    Jun 2005
    Massachusetts
    Posts
    1,540
    I'm told the new mini splits are effective to several degrees below zero now. I don't think there is any backup resistive heaters in these newer units
  3. #23
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    9,614
    Having a house in Michigan with a basement, I can tell you this: Even in the worst winters, the basement will very seldom get cold enough to freeze the pipes in the winter, and it gets below 0F. The reason is the fact that the ground around and under the basement stays about 54 degrees. People around here have their water pumps in unheated pump houses that are partially underground to take advantage of that.
    A heater set at 40F in a basement would hardly ever need to be on.
    Cheers and Stay Safe,
    Marky the Sparky
  4. #24
    Join Date
    Mar 2008
    Posts
    9,614
    Quote Originally Posted by mkgrady View Post
    I can't imagine doing laundry in a room that is only 40 degrees.
    Mine gets as low as 49 degrees in the winter, but that's just when you start. The washer and dryer put out heat and raise the temp in the area by several degrees. There are also things you can put in your dryer ducts to vent the warm air from the dryer into the house.
    Marky the Sparky
  5. #25
    Join Date
    Mar 2008
    Posts
    9,614
    Insulating and vapor proofing the area above the block walls will help, and it's not that hard to do. Also, if there are windows in the basement, make sure they are tight, if not, put some in that are. It is much cheaper to keep heat in the room than to 'heat the outdoors'.
    Marky the Sparky
  6. #26
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    18,765
    Quote Originally Posted by K8MHZ View Post
    ... There are also things you can put in your dryer ducts to vent the warm air from the dryer into the house.
    Which, although it may warm the house, may also raise the humidity to the point that harmful condensation occurs in visible or hidden parts of the building.
    There may be heat exchangers available instead, but they are likely to be inefficient and to easily clog with lint.
  7. #27
    Join Date
    Mar 2008
    Posts
    9,614
    Quote Originally Posted by GoldDigger View Post
    Here in the winter, the air is usually so dry we need humidifiers. At it's worst, I was using over a gallon a day. You do have a good point though, pretty much all the water from the wet clothes will go into the air.
    Marky the Sparky
  8. #28
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,707
    Some of the newer washers spin at even higher speeds then they used to and extract even more water from clothes. I've noticed some come out not needing much drying .
  9. #29
    Join Date
    Jun 2005
    Massachusetts
    Posts
    1,540
    Thanks for all the responses guys. I will probably install 4kw of baseboard heat and tell the customer to insulate the block walls and keep out any drafts. I don't think there is a line volt tstat that goes as low as 40 so I will use a low volt and have it turn on a relay. I will also give him an indoor/outdoor wireless thermometer so he always knows the the temp is in the basement without going down there
  10. #30
    Join Date
    Mar 2008
    Posts
    9,614
    I have a LUX line volt tstat that goes as low as 45.
    Marky the Sparky
Posting Permissions
  • You may not post replies
  • You may not edit your posts
