Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Recommendations for affordable LED bulb
  1. #1
    Join Date
    Aug 2017
    Alabama
    Posts
    9
    I'm upgrading some of the electrical & lighting at my current residence. One of the electricians gave me a wall pack luminaire (metal halide/400W) and I'm planning to install it above my garage, ~12-15 feet up in the air. Since I'm wanting to go LED, I've done the bypass ballast, and started looking at LED bulb options. So I'm seeing corncob LEDs and other styles in the price range from $60 up to $220. Anyone know of anything a bit cheaper?
  2. #2
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    37,970
    Quote Originally Posted by Lock Nut View Post
    If you can find one that puts out similar light as a 400 watt metal halide for $60 that is cheap.
  3. #3
    Join Date
    Jun 2010
    Posts
    1,928
    Just because you were given a 400W size doesn't mean you have to try to match the output. A 400W MH at home on a wall pack above garage would be insane. Matching a 400W MH lamp on the cheap with LEDs is not possible. LED generated lumens are still costly
  4. #4
    Join Date
    Aug 2017
    Alabama
    Posts
    9
    Quote Originally Posted by Electric-Light View Post
    Sure, I understand that. Since there's already a pole mounted security light near the corner of the yard, a 400-W MH would prove to be above and beyond what I actually need; I'm shooting more for efficiency here. Looking for an LED that would have a "____ watt replacement" value lower than that, decently priced, if feasible
  5. #5
    Join Date
    Jun 2003
    NE (9.1 miles @5.07 Degrees from Winged Horses)
    Posts
    9,967
    The prices are dropping continually but you have to decide what is a decent price. My budget may differ from yours.
    Tom
    TBLO
  6. #6
    Join Date
    Dec 2013
    Kansas Cty, Mo, USA
    Posts
    478
    I would think the only way you're going to get that kind of wattage at the price you're looking for is to roll the dice with something on Amazon, like:
    https://smile.amazon.com/E39-Lumens-...nt+street+lamp
  7. #7
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    37,970
    I installed a LED wall mount fixture that looks sort of like traditional wall packs, came from Home Depot and only cost around $25. No where close to the light output of a 400 watt MH but would be reasonable for most locations like OP has.
  8. #8
    Join Date
    Dec 2013
    Kansas Cty, Mo, USA
    Posts
    478
    Quote Originally Posted by kwired View Post
    That was my thought, too. I don't think I would bother with trying to put a corn bulb into an enclosed fixture
    I was looking at doing that at a Taco Bell I rewired a few years ago, and I decided against it after talking with several manufacturer reps.
    LEDs and the drivers need heat dissipation. I would imagine they all have a built-in cooling fan by now, but that doesn't help the heat to leave the fixture if it's enclosed
  9. #9
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    10,028
    I have an old outdoor light, I think it's MH, mounted at 15' above my garage door. It's 175 watt and that is plenty. For security purposes, realize that more watts will not only give you more light, it will give 'darker' shadows if it is the only light on.
    Cheers and Stay Safe,
    Marky the Sparky
  10. #10
    Join Date
    May 2010
    southwest Missouri
    Posts
    85
    I have installed many of these and have them at our lake home. It doesn't shine in your eyes, wow what an idea!
    https://www.samsclub.com/sams/led-se...lp:product:1:4
Posting Permissions
  • You may not post replies
  • You may not edit your posts
