Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 44
Thread: Hypothetical
  1. #11
    Join Date
    Oct 2009
    Austin, TX, USA
    Posts
    8,946
    Quote Originally Posted by JFletcher View Post
    Voltage gradient changes quite a bit for fresh vs saltwater. Dirty water, no telling where that falls. If possible, de-energize the house before entering. I do not know the proper protocol or safety measure one should take in entering a powered dwelling that's still underwater. istm to be premature at that point. If I had to do it, and I'm not recommending this at all, but if it were me, I'd have a set of rubber hipwaders on, rubber gloves, make my way to the panel and kill power. If the water around the house has receded, I'd pump out a basement with a portable gas powered pump before entering it.
    Residential basements are rare to nonexistent in Houston.
  2. #12
    Join Date
    Sep 2008
    UK
    Posts
    10,701
    Quote Originally Posted by Shaneyj View Post
    Doing flood clean up here in Houston and an interesting question comes up.
    What are the physics behind a 120v outlet being submerged in water... Assume a living room with several outlets submerged. Circuit stays energized.
    Jraef has kindly provided a link to procedures for refurbishing/replacing equipment that has been water damaged. None of the procedures are carried out live.
    Personally, I wouldn't consider entering a building with live, submersed electrical equipment. I think many others wouldn't either so, to that extent it is a hypothetical and the question of how well the type of water conducts is an irrelevance. IMO.
  3. #13
    Join Date
    Oct 2016
    Katy, Texas
    Posts
    37
    Quote Originally Posted by Besoeker View Post
    The physics of the scenario is what intrigued me. If you read my other posts you would see that safety is my real world concern.
    Nowhere in my post did I suggest I was gathering information in order to attempt the scenario you described.
    Sent from my HTC6545LVW using Tapatalk
  4. #14
    Join Date
    Sep 2008
    UK
    Posts
    10,701
    I described it as hypothetical. Which is agreeing with your take.
  5. #15
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    9,617
    Is there one? To me, that's like asking if there is a proper protocol for entering a powered dwelling that is on fire. The only way one should do either is in a life or death situation, IMHO.
    Cheers and Stay Safe,
    Marky the Sparky
  6. #16
    Join Date
    Sep 2008
    UK
    Posts
    10,701
    Quote Originally Posted by K8MHZ View Post
    Nicely put.
  7. #17
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,756
    I don't think OP was necessarily asking how to enter the flooded house while circuits are energized, I think he was asking what goes on in submerged energized wiring.
  8. #18
    Join Date
    Sep 2008
    UK
    Posts
    10,701
    Quote Originally Posted by kwired View Post
    What could go on since it's hypothetical.
  9. #19
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,756
    I think hypothetical meant there is no specific case he is referring to, just a general question of what happens when energized 120 volt item is submerged in water.
  10. #20
    Join Date
    Sep 2008
    UK
    Posts
    10,701
    Then he have simply asked that general question. Nothing hypothetical about it.
    Somewhat related, I've been to quite a few different countries and have seen practices that many would have raised eyebrows at.
    One was motor maintenance in the Far East. The motors were dismantled, the end bells and rotor removed. The stator was flushed out with water and then left to dry in the baking hot sun. Means and resources. So getting something soaked isn't the end of the world Operating it under such conditions is another matter.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
