Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
Thread: Hypothetical
  1. #21
    Join Date
    Jul 2005
    LA basin, CA
    Posts
    1,781
    Quote Originally Posted by Shaneyj View Post
    The physics of the scenario is what intrigued me.
    Electricians intelligently discussing principles of physics is less likely than blow-up dolls in passenger seats convincing police officers they are not a dummy.
    Roger Ramjet NoFixNoPay
  2. #22
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    9,851
    Quote Originally Posted by ramsy View Post
    Especially if the electricians have never watched Big Bang Theory.
    Cheers and Stay Safe,
    Marky the Sparky
  3. #23
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    36,774
    Quote Originally Posted by Besoeker View Post
    The motors were dismantled, the end bells and rotor removed. The stator was flushed out with water and then left to dry in the baking hot sun. Means and resources. So getting something soaked isn't the end of the world Operating it under such conditions is another matter.
    I will admit to having done that, would say I removed more problems then I added in every case.
  4. #24
    Join Date
    Sep 2008
    UK
    Posts
    11,380
    Quote Originally Posted by kwired View Post
    Yes. Not saying it's a bad thing. It's just not done here. We have a temperate climate that generally does not get hot enough for long enough to make it an effective tenique.
    Last edited by Little Bill; 09-10-17 at 11:45 PM. Reason: Removed controversial comments
  5. #25
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    36,774
    Yes. Not saying it's a bad thing. It's just not done here. We have a temperate climate that generally does not get hot enough for long enough to make it an effective tenique. With global warming, hoo nose........
    But it might get worse. Our moderate climate owes much to the Gulf Stream - thank you Mexico........
    I've read that some experts think warming will push the Gulf Stream into more northerly latitudes. Goodbye GB, hello Iceland?
    If you qat a plant with a steam system and mixing valves for hoses you can wash them out with some pretty hot water, takes grease off with little or no detergents, and leaves it hot enough it dries pretty quickly.
  6. #26
    Join Date
    Oct 2016
    Katy, Texas
    Posts
    55
    Then he have simply asked that general question. Nothing hypothetical about it.
    Somewhat related, I've been to quite a few different countries and have seen practices that many would have raised eyebrows at.
    One was motor maintenance in the Far East. The motors were dismantled, the end bells and rotor removed. The stator was flushed out with water and then left to dry in the baking hot sun. Means and resources. So getting something soaked isn't the end of the world Operating it under such conditions is another matter.
    You still haven't added anything of value to my question. And since you're hung up on my wording, just for you I will ask the question without the word hypothetical this time...
    Rather than me typing it, just imagine I didn't use that word, and feel free to insert any other word that is more likely to get you to share your ideas or knowledge.
    Your bio says EE. You are the type of audience I was appealing to.
    Sent from my HTC6545LVW using Tapatalk
  7. #27
    Join Date
    Jul 2013
    Renton, WA
    Posts
    824
    ...physics behind a 120v outlet being submerged in water... Assume a living room with several outlets submerged. Circuit stays energized.
    One of the basics of PHYSICS is experimentation.
    To answer your own question, take a plastic bucket of the flood water (in a dry place) and put an outlet into the water connected to a cord and plug set.
    Plug it in - observe. Depending on the water mineral/acid/base content, you will generate various levels of slight to vigorous steam bubbles. Measure the current. Count the outlets on that circuit, multiply - will the breaker trip?
    Sprinkle some salt (NaCl or any other salt) into the water, watch the current rise. Do same thing with HCl or vinegar, again watch current rise.
    Taking physics a step further, correlate amount of steam generated with current and heat of vaporization of water to verify the various formulatin of the laws of electrolysis,
    etc.......
    etc....
    BTW, to see if the power has failed during storm with no one present, look at any 60 Hz clocks you may still use clocks. To see if your freezer protected the contents while power off, see if there is anything left of the single ice cube you placed on the shelf inside.
  8. #28
    Join Date
    Sep 2008
    UK
    Posts
    11,380
    I actually agreed with your wording.
    If the room has several outlets I assume that all would be on the same supply so the electric fields could get quite complex.
    We used directly water cooled SCR heatsinks in high current rectifiers in a hexaphase configuration. End to end on phase to antiphase would be about 100V so not hugely different to your 0-120V domestic supply. Conduction through the water wasn't a problem. The water was circulated through coolers so, apart from leakage, the same water was recycled.
    An experiment we did at secondary school was to use electrolysis to split water into oxygen and hydrogen. We used regular tap water but it had to be laced with a little sulphuric acid to get the process to go a bit quicker.
    FWIW, I have just checked our cold water with the probes about an inch apart and got around 300kohms.
  9. #29
    Join Date
    Mar 2008
    Posts
    9,851
    This is not hypothetical. Is true.
    Marky the Sparky
  10. #30
    Join Date
    Mar 2008
    Posts
    9,851
    Here's more!
    Marky the Sparky
Posting Permissions
  • You may not post replies
  • You may not edit your posts
