Results 1 to 6 of 6
Thread: Cutting Riser Feeders
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,029
    If you have a long vertical riser, say 120’, of #600 mcm andyou must cut the feeders to make a splice are there any precautions one musttake due to the stress(if any) on the wire? Could something dangerous happen when the cuts are made? I’mthinking there should be cable supports in the box. Thanks.
  2. #2
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,375
    If the riser conductors are already properly supported you might not need to do anything. If you're cutting right above the cable support then no problem, if you're cutting 3 floors above then you might want to take some precautions.
    Rob
  3. #3
    Join Date
    Sep 2012
    NJ
    Posts
    2,029
    Quote Originally Posted by infinity View Post
    Thanks. This forum should add a "like" button.
  4. #4
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,285
    You are not able to make an insulation piercing splice?
    Fortunately wire does not stretch much.
    A buddy of mine was caving (spelunking) once and had just enough nylon climbing rope to reach the bottom of a deep pit.
    When he got to the bottom and let go of the rope the end sprang back about ten feet above his reach. .
  5. #5
    Join Date
    Oct 2015
    US
    Posts
    624
    Quote Originally Posted by GoldDigger View Post
    Wow how did he get out i see many movie scenes in my head right now
    Sent from my SM-G950U using Tapatalk
  6. #6
    Join Date
    Dec 2012
    Posts
    19,285
    Quote Originally Posted by nickelec View Post
    One of his buddies was still at the top of the pit ....
Posting Permissions
  • You may not post replies
  • You may not edit your posts
