Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Anyone ever see AL entrance cable conductor undersized AWG from the factory??
  1. #1
    Join Date
    Apr 2009
    Posts
    209
    Got some SE cable the other day, Kingwire 3 wire Aluminium , and one of the two insulated conductors was visibly smaller than the other, though both were supposed to be 2/0. Noticed it after I cut it down in the meter housing, a bit late. Sure enough it seemed like a burnt wire, it was discoloured.. a brownish tint when you cut the insulation back, and it was compressed tightly, the strands were stuck together, it was noticeably smaller than the other insulated conductor. - Anyone ever see this on supposed brand new wire?
    Guy at the counter said "nah, its just extruded that way when they made it, or it's just the way it's cut." .but no..it was like that the whole 50' I bought. Another counter guy was more concerned and took my sample with him.
    AWG goes by diameter, right?
  2. #2
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    4,425
    Never seen that. Pics would have been great. Worst I've seen is coax with flat spots and out of roundness, and the braids visibly compressed and damaged in spots. I believe it was Carol brand cable from a BB store.
    Sounds like someone loaded up a wrong spool at the factory to make the triplex.
  3. #3
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    18,616
    Well, it goes by area, which is proportional​ to diameter squared for a constant wire geometry.
    Normal stranded has a larger diameter than solid for same area. But stranded can also be "compact" with the strands compressed to fit with less or no air space. That is common for aluminum wires.
  4. #4
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,177
    As Digger stated it cold be that one conductor is compact and the other isn't. Photo's available?
    Rob
  5. #5
    Join Date
    Jan 2011
    United States
    Posts
    6,894
    Pics or its not real
    What is esoteric knowledge today will be common knowledge tomorrow.
  6. #6
    Join Date
    Apr 2009
    Posts
    209
    Allright, I left the prime example with the supply house. I should be able to come up with a pic, am still on this job.
  7. #7
    Join Date
    Apr 2009
    Posts
    209
    Quote Originally Posted by infinity View Post
    Could be that one conductor is compacted to too small a wire gauge.
  8. #8
    Join Date
    Apr 2009
    Posts
    209
    OK finally got the pics. You can see if you look enough the red striped CC conductor appears smaller than the other. Also the wire itself appears tinted a bronzish color . Both have 19 smaller strands. Myself and my witness here both say the one is smaller than the other diameter wise.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	18518   Click image for larger version.
ID:	18519   Click image for larger version.
ID:	18520   Click image for larger version.
  9. #9
    Join Date
    Jan 2011
    United States
    Posts
    6,894
    Hard to tell from the pics, but one does indeed look slightly smaller. Not by much, but slightly undersized by 1/2 to 1 gauge. Could be that the black is larger. How do both these conductors compare to known normal SEU cable?
  10. #10
    Join Date
    Jul 2015
    Wilmington, NC USA
    Posts
    281
    I agree one looks slightly smaller, and that would concern me a little about quality control of that manufacturer.
    I used to wire a lot of marinas and I found that the copper conductors of one manufacturer of type W cable (I think it was #2) were slightly smaller than another. I called the manufacturer rep and he said he would look into it. Got back to me and said their wire was fine. Well, I know for a fact that they had less copper than General did.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
