Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: AC formulae and power analysis etc
  1. #1
    Join Date
    Apr 2014
    California
    Posts
    1
    Hi
    Is my categorization of complex power S into phasor form, polar form, and rectangular form correct? Did I miss any category? Thank you for your help.
    Attached Images Attached Images
  2. #2
    Join Date
    Dec 2008
    Posts
    516
    The first and the second line formulae are correct.
    The third line result has to be: P=Vrms^2*R/(R^2+X^2) and Q=Vrms^2*X/(R^2+X^2) since: (R-jX)*(R+jX)=R^2+X^2
  3. #3
    Join Date
    Jan 2016
    PA
    Posts
    5,495
    He did not need to use the conjugate for S = v^2/Z
    The difference between genius and stupidity is that genius has its limits.
  4. #4
    Join Date
    Jan 2011
    United States
    Posts
    7,295
    Quote Originally Posted by Ingenieur View Post
    Quick question- what is "conjugate"?
    I'm in over my head...
  5. #5
    Join Date
    Jan 2016
    PA
    Posts
    5,495
    Quote Originally Posted by mbrooke View Post
    If I = 100/60 deg = 50 + 86.6 j
    I* = 100/-60 deg = 50 - 86.6 j
    changing sign on complex portion
    S = V I* iirc
  6. #6
    Join Date
    Jan 2011
    United States
    Posts
    7,295
    S = V I* iirc
    (*) as in degrees?
  7. #7
    Join Date
    Jan 2016
    PA
    Posts
    5,495
    (*) as in degrees?
    No it's the symbol for the conjugate of the qty
    like '!' is the symbol for factorial
    if you had phasor analysis you used conjugate
    S = V (conjugate of I) = V I*
  8. #8
    Join Date
    Dec 2008
    Posts
    516
    [QUOTE=Ingenieur;1858884]He did not need to use the conjugate for S = v^2/Z[/QUOT
    IEEE Std 1459-2010, IEEE Standard Definitions for the Measurement of Electric Power Quantities Under Sinusoidal, Nonsinusoidal, Balanced, or Unbalanced Conditions. 3.1.1.3 Reactive power (var)
    “NOTE 1— If the load is inductive, then Q > 0. If the load is capacitive, then Q < 0. This means that when the current lags the voltage θ > 0 and vice versa.”
    Using Z=R+jX instead of Z*=R-jX the resulted Q<0 [capacitive].Usually X is inductive.
  9. #9
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,256
    [QUOTE=Julius Right;1858996]
    Yes he did!
    Actually, the resulting Q2 is always positive, allowing Q to be either positive or negative.
    If you do simple complex multiplication without the conjugate you get a negative value for
    q2, which is impossible, and you get cross terms which still contain j, also unphysical for power.
  10. #10
    Join Date
    Sep 2008
    UK
    Posts
    11,399
    Quote Originally Posted by pg1995 View Post
    Hi
    Nice cut and paste job (twice) but what point were you, the OP, endeavouring to make?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
