Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
Thread: How many circuits do I need to existing Laundry Room?
  1. #11
    Join Date
    Jun 2003
    NE (9.1 miles @5.07 Degrees from Winged Horses)
    Posts
    9,617
    Bite the bullet, make it as new and don't forget those nasty AFCI if required.
    Tom
    TBLO
  2. #12
    Join Date
    Feb 2006
    Jersey
    Posts
    2,232
    I would love to.
    I'll give it another look but not a piece of cake to get it back to the panel
    Thank you
    " I'm at a crucial part of my painting "...........Monika Danneman
  3. #13
    Join Date
    Feb 2003
    Minnesota
    Posts
    6,775
    Quote Originally Posted by ritelec View Post
    Thank you all. Sorry didn't mention the receptacle need to be moved a couple feet.
    The receptacle needs to be relocated.
    I would think that would require an electrician ???
    Please correct me if I'm wrong ? Also. There's no receptacle by the little sink. Was going to throw one in
    Still rehab code ?
    The "thrown in" receptacle is a "new outlet" in an area that is a Bath. I am not extremely familiar with the Jersey Rehab Code, but, to me, this one is simple. As a new outlet in the Bath, the outlet must satisfy the new construction Code in effect at that ranch dwelling.I seem to recall that the Jersey Rehab Code does limit the application of AFCI and GFCI in rehab areas.
    Another Al in Minnesota
  4. #14
    Join Date
    Feb 2006
    Jersey
    Posts
    2,232
    Ok. So it was existing and I relocated it or I don't install one.
    Does that put me back in the game ?
    Thank you
    Edit. Was thinking if there was one in the laundry by the sink area ...which there may be but I didn't see it :- )
    Then it was part of the existing laundry right
    Or as mentioned , no extra plug by sink
    Wow but what if i just added a receptacle on a wall by the sink but not at the sink height but down low. Or even on another wall for convenience?
    Does adding a plug add to the laundry circuit or potential new bath.
    Guess it could be twisted either way.
    As mentioned. Would think the extra bath circ should be there. But. Well old people. Not easy to get to panel. Lack of $$$.
    We'll see how it plays out.
    Thanks for all of the advice
  5. #15
    Join Date
    Nov 2007
    Livonia, Michigan
    Posts
    233
    Quote Originally Posted by Dennis Alwon View Post
    Look up the definition of bathroom. The NEC requires a circuit for the bathroom receptacle. It also requires one for the laundry
    Yes, that's what I would say as well. As long as you have dedicated circuits for the laundry and bathroom receptacles, you're good. The lighting can (and should) be wired to the existing lighting circuit. But most importantly, be sure you sell them on a new panel and get that dangerous FPE panel out of there! If they say they can't afford to, you need to say "Can you afford not to?".
  6. #16
    Join Date
    Feb 2006
    Jersey
    Posts
    2,232
    Readily accessible laundry recept ??
    Thank you. Well the inspector called with questions. As per the rehab code I could tap off the lighting circ for the sink receptacle, however gas dryers are not permitted in bathrooms
    So the plans are going to change to flip this into the garage and do this and that .... So I said plan on a route to the panel for new circuits and a new service. Is what it is.
    Question : in talking to the inspector he mentioned the washer dryer receptacle (120 v ) couldn't be behind the washer dryer. ???? They (it) need to be accessible.
    You can't put a receptacle about 4 ' high on a wall behind a washer dryer anymore that they can plug into ??
    It has to be to the side ?
  7. #17
    Join Date
    Apr 2003
    Fort Collins, Colorado
    Posts
    1,664
    A GFI receptacle has to be readily accessible. That might be what he's thinking?
    Barring any local codes, you most certainly can put a receptacle behind the washer, fridge, etc.
    Ron
  8. #18
    Join Date
    Feb 2006
    Jersey
    Posts
    2,232
    Ok. Thanks for clarifying.
  9. #19
    Join Date
    Dec 2008
    Posts
    206
    I think the inspector means that you can not hide the receptacles behind the washer and dryer. They are a disconnecting means so must be accessible. I put mine at 48" to the top of the outlet boxes…next to the water supply valves and standpipe.
  10. #20
    Join Date
    Feb 2003
    Somewhere over the rainbow
    Posts
    3,279
    Quote Originally Posted by mlnk View Post
    I don't think the disconnecting rule applies. The inspector is probably thinking about the GFCI accessibility requirement.
    Edward
    The only thing I know, is the progressive discovery of my ignorance
Posting Permissions
  • You may not post replies
  • You may not edit your posts
