Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: How many circuits do I need to existing Laundry Room?
  1. #1
    Join Date
    Feb 2006
    Jersey
    Posts
    2,232
    Hello all.
    There's a older ranch, it has a laundry room. Theres a washer, dryer. Theres also a sink and a toilet.
    It has a separate 120v 20a circuit to it.
    A contractor will be adding a shower in the room.
    Is it now a laundry AND a bath room ?? Will I need two circuits or is it now a laundry with a shower and one circuit will suffice?
    I would just run the extra circ. but it would be VERY difficult to get back to a Packed Federal Pacific and the owners are elderly and are adding the shower cause they have difficulty walking and look a bit low on the $$.
    Thank you
    " I'm at a crucial part of my painting "...........Monika Danneman
  2. #2
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    33,141
    IMO, you need a circuit for the laundry area and one for the bath
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  3. #3
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    9,848
    Will adding a shower put an extra load on the circuits that supply the area?
    If yes, like a light and a fan, then I would not argue with having to run an additional circuit. If not, I don't see how adding a place for water to come out would mandate any change of the electrical wiring, or even be logical to make or require such a change.
    Cheers and Stay Safe,
    Marky the Sparky
  4. #4
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    33,141
    Quote Originally Posted by K8MHZ View Post
    Look up the definition of bathroom. The NEC requires a circuit for the bathroom receptacle. It also requires one for the laundry
  5. #5
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,170
    It always was a bathroom by definition so IMO the shower does not change a thing.
    Rob
  6. #6
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    33,141
    I stand corrected -- it was always a laundry and a bathroom so yes 2 circuits are required. It may not have been done originally but IMO you may be forced to upgrade it as required by nec
  7. #7
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,170
    Quote Originally Posted by Dennis Alwon View Post
    In NJ the rehab code would not require him to add anything.
    Rob
  8. #8
    Join Date
    Feb 2003
    Seattle, WA
    Posts
    18,968
    With what the OP has posted so far, I don't see the need for an electrician to get involved in the project.
    Charles E. Beck, P.E., Seattle
    Comments based on 2017 NEC unless otherwise noted.
  9. #9
    Join Date
    Jun 2003
    NE (9.1 miles @5.07 Degrees from Winged Horses)
    Posts
    9,604
    Quote Originally Posted by charlie b View Post
    Tom
    TBLO
  10. #10
    Join Date
    Feb 2006
    Jersey
    Posts
    2,232
    Thank you all. Sorry didn't mention the receptacle need to be moved a couple feet.
    The receptacle needs to be relocated.
    I would think that would require an electrician ???
    Please correct me if I'm wrong ? Also. There's no receptacle by the little sink. Was going to throw one in
    Still rehab code ?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
