Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Chop or Core Wall
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    1,852
    Chop or Core Wall
    If you had (4) 4" conduits going through a masonry bock wall(existing) would you chop out a "window" or core individual holes. I believe it's usually an opening made with hammer drill. Thanks.
  2. #2
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,147
    Are the blocks hollow or solid cored?
    If it's hollow just bash though with a single jack sledge hammer.
    If you go and decide to dance with a gorilla the dance ain't over till the gorilla decides it's over.
  3. #3
    Join Date
    Sep 2012
    NJ
    Posts
    1,852
    Quote Originally Posted by ActionDave View Post
    To be honest, I don't know.
  4. #4
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    9,619
    Quote Originally Posted by mstrlucky74 View Post
    You should probably find out, as it makes a big difference as to the preferred method.
    Cheers and Stay Safe,
    Marky the Sparky
  5. #5
    Join Date
    Sep 2012
    NJ
    Posts
    1,852
    Quote Originally Posted by K8MHZ View Post
    Ok, thanks.
  6. #6
    Join Date
    Jun 2016
    Tampa, FL, USA
    Posts
    1,164
    With 4-4" conduits going through the wall, that is the equivalent of taking out two full blocks. You might not have any issue if you spread them out, but if they are close together, the blocks above may lose stability. In that case, a metal lintel (basically angle iron) should probably be installed above the removed sections. I would consult a block mason. Coring is probably more stable since you are leaving more material in place.
  7. #7
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    4,617
    I'd put 2 holes in one block and 2 in another. Avg block is 8"H x 16"L, you're not getting 4 4" conduits thru one block. I'd just as soon not have to use large fire stop bricks to seal the opening or pay a mason to fix the hole.
  8. #8
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,383
    As Dave mentioned if it's solid filled then core drill, if the blocks ares still hollow then chop the hole. Solid filled walls also may have rebar in them which is easier to core drill through.
    Rob
  9. #9
    Join Date
    Sep 2012
    NJ
    Posts
    1,852
    Thanks guys. Are block walls most always the hollow cored type?
  10. #10
    Join Date
    Dec 2010
    Tennessee NEC:2008
    Posts
    4,414
    Not most always, if the block is below grade or being used to hold side pressure then they are filled. Probably other reasons as well.
    If you aim at nothing, you will hit it every time!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
