Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
Thread: Multiwire Branch Ciruits
  1. #11
    Join Date
    Jul 2004
    Louisville, Kentucky
    Posts
    2,135
    Quote Originally Posted by Ondarc View Post
    Just a quick question, any input is welcome and very much appreciated. When and how is it legal according to the 2017 NEC to use 12/3 NM-B cable for multiple receptacle or lighting circuits in a residential setting?
    Thanks.
    You might also want to consider using either 12/2/2 or 14/2/2 NM for this type of installation. You have two separate circuits but only one cable/homerun.
    Norb
    My Boss is a Tyrant and my Employee is an Idiot.
  2. #12
    Join Date
    Jul 2004
    Posts
    2,135
    Thanks.
    Norb
  3. #13
    Join Date
    Feb 2007
    USA
    Posts
    5,384
    Quote Originally Posted by 1793 View Post
    You save one ground wire!
  4. #14
    Join Date
    Jul 2004
    Posts
    2,135
    Quote Originally Posted by Sierrasparky View Post
    That is another benefit. I use these cables quite a bit on remodels and room additions.
    Norb
  5. #15
    Join Date
    Feb 2007
    USA
    Posts
    5,384
    Do you see that big of a labor or material savings? That stuff is about 45% more in cost.
    I see the use for heat fans and such that have multiple switch legs.
  6. #16
    Join Date
    Jul 2005
    LA basin, CA
    Posts
    1,626
    Quote Originally Posted by GoldDigger View Post
    Maybe the residence in question is off-grid?
    Residences in Florida and several US territories went off grid, after recent hurricanes.
    710.15(C) prohibits MWBC's for "Stand-Alone Systems" preferred in off-grid areas.
    WARNING:
    SINGLE 120-VOLT SUPPLY. DO NOT CONNECT MULTI‐
    WIRE BRANCH CIRCUITS!
    The warning sign(s) or label(s) shall comply with 110.21(B).
    Roger Ramjet NoFixNoPay
  7. #17
    Join Date
    Jun 2008
    Diamond bar, CA , Tempe AZ
    Posts
    338
    Quote Originally Posted by ramsy View Post
    WARNING:
    I don't think the OP being in New York is concerned about off grid applications. I could be mistaken.
  8. #18
    Join Date
    Jul 2005
    LA basin, CA
    Posts
    1,626
    Quote Originally Posted by flatlander View Post
    Whats A-Matter You, Why You Looka So Sad, It's A-Not So Bad, just because this topic is relevant to Residential "Stand-Alone Systems" that are installed everywhere, not just Off-Grid areas.
  9. #19
    Join Date
    Jun 2008
    Posts
    338
    I so sorry did I hurt your feelings
  10. #20
    Join Date
    Oct 2015
    US
    Posts
    374
    With the op being from NYC your only allowed to uses NM in residential buildings 3 stories or less
    Sent from my SM-G950U using Tapatalk
Posting Permissions
  • You may not post replies
  • You may not edit your posts
