View Poll Results: When pulling wire from spools. Are you pulling from top or bottom?
Voters
15. You may not vote on this poll
  • Bottom
    5 33.33%
  • Top
    10 66.67%
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Pulling wire, top or bottom? And why?
  1. #1
    Join Date
    Jan 2014
    Camden county NJ
    Posts
    8
    When you are pulling MC, THHN, Romex from a spool do you pull the wire from the bottom or from the top? And why?
  2. #2
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    18,773
    From the top so that the wire is farther off the ground and easier to get to the start of the pull?
  3. #3
    Join Date
    Apr 2008
    Austin, TX
    Posts
    1,156
    You forgot to include the optimum THHN pulling set-up in your poll. I had a journeyman that alternated up/down/up/down especially for reels that had different lengths on them. This set-up prevents overrunning by providing braking to adjacent rolls.
    Typically, I come off the top to pull undergrounds and off the bottom for going out the top of a panel. For large spools of 3/0 or 500kcmil, I pull from the bottom because in my mind the lower center of gravity helps keep the reel from falling off the stands.
  4. #4
    Join Date
    Dec 2012
    Posts
    18,773
    Quote Originally Posted by jeremysterling View Post
    The center of gravity really does not change much, unless you count the weight of the unspooled but not yet supported cable. But the point at which the unspooling tension is applied does change.
    All in all, I think this is a lot like which way to roll toilet paper....
  5. #5
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    4,605
    Havent pulled that much from spools but THHN from smaller ones. Not on the option, but whenever I've pulled lots of catx/CATV at once, sometimes 20+ cables, it all spins the same way (usually off the top) to minimize drag and pulling tension since you're not supposed to exceed 25lbs force.
  6. #6
    Join Date
    Jan 2014
    Camden county NJ
    Posts
    8
    Bottom! More recently I have been pulling from the bottom to stop the wire from jumping off and snagging around the axle. It never happens when pulling from the bottom.
  7. #7
    Join Date
    Feb 2016
    Illinois
    Posts
    690
    Quote Originally Posted by GoldDigger View Post
    In other words, always from the top!
  8. #8
    Join Date
    Jan 2014
    Camden county NJ
    Posts
    8
    Quote Originally Posted by retirede View Post
    I agree with the toilet paper direction. But wire is not toilet paper.
  9. #9
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,145
    Quote Originally Posted by wirenut45 View Post
    I agree. I am a firm believer in pulling from the bottom for this reason.
    If you go and decide to dance with a gorilla the dance ain't over till the gorilla decides it's over.
  10. #10
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    14,085
    For the most part ditto. Situations vary.
    "Electricity is really just organized lightning." George Carlin
    Derek
Posting Permissions
  • You may not post replies
  • You may not edit your posts
