Results 1 to 2 of 2
Thread: Intercepting @ Cable Tap Box
  1. #1
    Join Date
    Sep 2012
    Curious...we have to intercept the feeders to the cable tapbox which feed the bus duct as you can see. They are showing theintercept of the pipes closer to the extg. to removed panel. IS there anyreason why we couldn’t make the intercept right at the cable tap box? Seem logicallyas that’s where the current pipes/wire end at the bus duct so we would justdisconnect those and run the new to that point. Any reason that couldn’t bedone at the cable tap box? New conduits and wire are same sixe as extg. to be removed.
    Attached Images Attached Images
  2. #2
    Join Date
    Jun 2017
    WI, USA
    The author of the drawing may have better knowledge of the existing conditions; otherwise, no reason why not.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
