User Tag List
Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: Mandatory backup power for HVAC systems in Heath Care Facilities
  1. #11
    Join Date
    Jan 2011
    United States
    Posts
    8,807
    Mentioned
    1 Post(s)
    Tagged
    1 Thread(s)
    Quote Originally Posted by don_resqcapt19 View Post
    My understanding is that the NEC only provides the installation requirements, and NFPA 99 specifies what is to be backed up. In 517, the requirements that tell what is to be backed up all have a [bracketed] reference to NFPA 99. That means the information preceding the brackets has been extracted from 99.
    Makes sense. So in order to change the NEC, I'd need to change 99, right?
    I'm in over my head...
  2. #12
    Join Date
    Feb 2003
    Illinois
    Posts
    24,012
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mbrooke View Post
    Probably no need to do anything with the NEC. Just a requirement that in 99 that those facilities have AC systems supplied by a back up power system.
    Don, Illinois
    (All code citations are 2017 unless otherwise noted)
  3. #13
    Join Date
    Sep 2017
    Claverack, NY, USA
    Posts
    15
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This type of requirement, if proposed should be in the building code, not the NEC
Posting Permissions
  • You may not post replies
  • You may not edit your posts
