Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: central inverters vs string inverters
  1. #11
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,079
    Quote Originally Posted by electrofelon View Post
    Yeah its weird. Seems like a huge advantage to me yet they don't promote it. Most of their literature says 600v. Dataplate says 1kv. Tech support will confirm 1kv is fine.
    One factor in why they do not promote it may be that for residential use the upper limit on array voltage is still only 600V, regardless of the inverter used.
  2. #12
    Join Date
    Oct 2009
    Austin, TX, USA
    Posts
    9,175
    Quote Originally Posted by GoldDigger View Post
    I haven't verified it for myself, but if it's true it sounds pretty stupid to me. Why would anyone publish an erroneous data sheet which will put them out of the running for many designs?
  3. #13
    Join Date
    Jun 2004
    Cherry Valley NY, Seattle, WA
    Posts
    4,122
    Quote Originally Posted by ggunn View Post
    This came up a while back, and I dont remember if fronius told me this, or I heard it from someone else, but they seem to think that since the primo are generally targeted for residential, no one cares about 1 KV strings, so they dont even bother to say it on the literature. The first time I used a primo, I designed for 600v. When I got the inverter, I saw 1000 on the dataplate. After some confusion and calls to fronius, I ended up stringing for 1000V, as this system was on a detached residential structure.
    Ethan Brush - East West Electric. NY, WA. MA
    "You can't generalize"
  4. #14
    Join Date
    Dec 2012
    Posts
    19,079
    If I were the inspector, I am not sure I would call that non-residential unless the detached structure was demonstrably and by zoning a commercial structure.
  5. #15
    Join Date
    Jun 2004
    Posts
    4,122
    Note that the restriction for 1kv is narrower than just "residential".
  6. #16
    Join Date
    May 2013
    Massachusetts
    Posts
    2,302
    Elaborate, please
  7. #17
    Join Date
    May 2011
    Posts
    4,073
    The wording is:
    'In one and two family dwellings, PV source circuits and PV
    output circuits that do not include lampholders, fixtures,
    or receptacles shall be permitted to have a maximum PV
    system voltage up to 600 volts.'
    690.7(C)
    That leaves open apartment buildings. Also leaves open ground mounted or detached structures structures where the PV source or output circuits aren't in the building.
  8. #18
    Join Date
    Jun 2004
    Posts
    4,122
    Quote Originally Posted by jaggedben View Post
    The wording is:
    690.7(C)
    thanks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
