Results 1 to 8 of 8
Thread: Any recommendations for guarding of ground mount arrays?
  1. #1
    Join Date
    Jan 2008
    Coventry, RI
    Posts
    70
    Our company sticks mostly with roof-mounted systems on single family houses, but we're branching out and doing a higher number of ground mounts. We've had them fenced in to meet the requirements of 690.33(B) (live electrical components [including PV wires beneath the array] shall be guarded) before, but it seems that there should be a product available that would attach directly to the underside of the modules.
    Anyone have any recommendations?
    Thanks in advance!
  2. #2
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,343
    Instead of a bolt on product, many use hardware cloth or similar metal mesh to construct a cover over the back of panel array.
  3. #3
    Join Date
    Jul 2012
    Chicago, IL
    Posts
    27
    Expanded aluminum is one option, but since it is conductive you may have challenges with bonding depending on the inspector. Another good option is a product called Solar Scrim. It's a little pricey, but non-conductive and less labor to install than most custom solutions. Works best with two rows of modules in portrait and with junction boxes facing each other.
    http://www.solarscrim.com/
    Good luck.
  4. #4
    Join Date
    Sep 2017
    Napa, CA, US
    Posts
    58
    I think the biggest problem you'll have with ground mounted arrays, is the number of ladders it takes to build them.
    From: http://forums.mikeholt.com/showthrea...54#post1861854
  5. #5
    Join Date
    Dec 2014
    Washington, USA
    Posts
    86
    Quote Originally Posted by ArcNSpark View Post
    Thanks in advance!
    We use simple corrugated metal panels to guard the conductors and such. I am not sure how they fasten it to the structure. But I know it is just the Home Depot corrugated panels you can pick off the shelf.
  6. #6
    Join Date
    Dec 2014
    Washington, USA
    Posts
    86
    Quote Originally Posted by Mark A. View Post
    Now that's funny!
  7. #7
    Join Date
    Jan 2008
    Coventry, RI
    Posts
    70
    Quote Originally Posted by Garrison View Post
    Good luck.
    This is exactly what I was looking for. Thanks for the recommendation!
  8. #8
    Join Date
    Jan 2008
    Coventry, RI
    Posts
    70
    Quote Originally Posted by Anode View Post
    Much appreciated!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
