Results 1 to 10 of 10
Thread: Core Drill Labor Units
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    2,029
    So NECA labor units have different labor units per 1/2" increments. Is there really a time difference between a 1" or 1-1/2 core...same for 2 to 2 1/2" I labor 1 and 1-1/2" the same and 2 to 2 1/2" so on and so on.
  2. #2
    Join Date
    Feb 2003
    Illinois
    Posts
    23,631
    Other than the actual drill time, the labor does not change for coring holes. The set up time and clean up time remains the same. On my industrial jobs, it would probably be 2 guys for 4 hours and I will use that no matter what size the core is.
    Don, Illinois
    Ego is the anesthesia that deadens the pain of stupidity. Dr. Rick Rigsby
    (All code citations are 2017 unless otherwise noted)
  3. #3
    Join Date
    Sep 2012
    NJ
    Posts
    2,029
    Quote Originally Posted by don_resqcapt19 View Post
    Thanks. So you are saying there is more drill time for a 2" compared to a 1-1/2"?
  4. #4
    Join Date
    Nov 2014
    MA
    Posts
    141
    The larger the hole the more time it will take to drill it, add rebar add time. Not sure how much to add but concrete cutting companies charge more for larger holes, I forget how much
  5. #5
    Join Date
    Feb 2003
    Illinois
    Posts
    23,631
    Quote Originally Posted by mstrlucky74 View Post
    Yes there is a bit more drill time as you increase bit size. Probably not enough to worry about.
    Don, Illinois
  6. #6
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,285
    And the larger the hole the more likely you are to hit a rebar (or two.)
  7. #7
    Join Date
    Feb 2003
    Illinois
    Posts
    23,631
    Quote Originally Posted by GoldDigger View Post
    And if it is right on the edge of a large hole where you have a lot of the cutting bit in the rebar, that really does slow you down.
    Don, Illinois
  8. #8
    Join Date
    Sep 2012
    NJ
    Posts
    2,029
    I thought they xray slabs prior to coring to check for rebar or embedded conduits.
  9. #9
    Join Date
    Dec 2011
    Ocala, Florida, USA
    Posts
    2,593
    Only when required.
    I know what I don't know, and I know where to go to find it!
  10. #10
    Join Date
    Dec 2012
    Posts
    19,285
    Critical for pre- or -post-tensioned concrete slabs because damaging a tendon is a serious (expensive) structural problem. And potentially a serious safety hazard as the ends explode out of their holes.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
