Results 1 to 6 of 6
Thread: HID lamp shapes
  1. #1
    HID lamp shapes
    does it matter if one were to interchange different shaped HID lamps?
    ...not the words of our enemies, but the silence of our friends MLK Jr.
  2. #2
    Join Date
    Oct 2007
    New Jersey
    Posts
    5,512
    Quote Originally Posted by elecold View Post
    If there is a reflector or lens involved, almost certainly. In those cases, the filament is designed to be a precise distance from the reflector/lens, and precise height above the base.
  3. #3
    Join Date
    Dec 2015
    Texas
    Posts
    112
    In addition to Gadfly's comment, which is the biggest issue, you also want to note the lamp orientation; some are universal burn, some are horizontal, and some are vertical only.
  4. #4
    thanks for your replies.
    where does it say what type should be installed?
  5. #5
    Join Date
    Oct 2007
    New Jersey
    Posts
    5,512
    You need to look at a cut sheet for your luminaire to find out what lamps are suitable and in what orientation. Grab the lamp ID of it and look it up in GE's or OSRAM's catalog to get additional info if you don't have a make/model for the luminaire.
  6. #6
    Join Date
    Jun 2003
    Posts
    6,875
    I agree, and if I remember correctly, the ANSI number of the ballast should match the ANSI number of the lamp used.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
