Results 1 to 9 of 9
Thread: Grounded
  1. #1
    Join Date
    May 2017
    cudahy,California
    Posts
    16
    Grounded
    Conduit installed underground, or encased in concrete slabs that are in direct contact with the earth, is considered a ______ location.
    Select one:
    a. damp
    b. wet
    c. dry
    d. moist
    can't find this answer on the code book
  2. #2
    Join Date
    May 2017
    cudahy,California
    Posts
    16
    grounded
    There must be no reduction in the size of the grounded conductor on _____ type loads.
    Select one:
    a. resistive
    b. nonlinear
    c. linear
    d. symmetric
  3. #3
    Join Date
    May 2017
    cudahy,California
    Posts
    16
    Quote Originally Posted by bennny123 View Post
    Select one:
    a. damp
    b. wet
    c. dry
    d. moist
    sorry wrong question
  4. #4
    Join Date
    Feb 2003
    Fl
    Posts
    17,167
    Read all the definitions of "Location" and 300.5(B).
    Roger
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,350
    Select one:
    a. resistive
    b. nonlinear
    c. linear
    d. symmetric
    Look around at 220.61.
    Rob
  6. #6
    Join Date
    May 2014
    AZ
    Posts
    2,324
    they are elimination questions, 3 of 4 do not make sense.
  7. #7
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    33,314
    Quote Originally Posted by infinity View Post
    I might add to read all parts of 220.61
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  8. #8
    Join Date
    Feb 2003
    New York, 40.7514,-73.9925
    Posts
    4,518
    bennny123
    Think about what the neutral does. If it carries imbalanced current for the most part, so which of those four loads may be wacky results for the neutral.
    And as mentioned, look around in 220.61
    Ron
  9. #9
    Join Date
    Feb 2003
    Fl
    Posts
    17,167
    I still don't know which question we should be addressing.
    Roger
Posting Permissions
  • You may not post replies
  • You may not edit your posts
