Results 1 to 2 of 2
Thread: Inverter on other side of a gate
  1. #1
    Join Date
    Mar 2015
    Berkeley, CA
    Posts
    74
    Hi,
    If I have a main panel separated from an inverter (maybe only 10 ft away from each other) by a gate, would I still need an AC disconnect, and therefore also a disconnect directory plaque? I'm not sure if the gate is locked or not.
    Regards,
    Andy
  2. #2
    Join Date
    May 2011
    Posts
    4,065
    I usually play that one safe and put in a disconnect. See the 'grouped' requirement in 690.15. Hard to argue that equipment on two sides of a gate is grouped.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
