Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Solid wire and crimping
  1. #1
    Join Date
    Feb 2003
    Somewhere over the rainbow
    Posts
    3,279
    Can solid wire (say #6 solid) be butt spliced using a crimped connection? I have never seen a solid wire crimped.
    Thank you.
    Edward
    The only thing I know, is the progressive discovery of my ignorance
  2. #2
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,531
    Quote Originally Posted by edward View Post
    Thank you.
    Some but by no means all butt splice connectors are rated for solid wire. I would expect to have to use a cycle controlled crimper to match the connectors. No universal crimp pliers if using solid wire.
    JMO
  3. #3
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,819
    Just curious, who uses #6 solid and why?
    Rob
  4. #4
    Join Date
    Jul 2007
    Clark County, NV
    Posts
    1,098
    Quote Originally Posted by infinity View Post
    Grounding of panels and other required equipment.
    Can't think where I've ever seen it spliced though.
  5. #5
    Join Date
    Feb 2003
    Posts
    3,279
    It is for GEC extension.
    The plumbers did a plumbing upgrade and the city has required a new grounding system. The plumbers did not do the GEC properly so the customer wants me to use a butt splice to extend the GEC to the panel and I refused to use a crimp and butt splice on the solid wire.
    I said I will replace the whole system properly without a butt splice.
    Edward
  6. #6
    Join Date
    Jun 2003
    NE (9.1 miles @5.07 Degrees from Winged Horses)
    Posts
    9,950
    Cadweld or similar should be adequate but may be more expensive than the new 6.
    Tom
    TBLO
  7. #7
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,707
    Irreversible crimp is all you need.
    If you go and decide to dance with a gorilla the dance ain't over till the gorilla decides it's over.
  8. #8
    Join Date
    Jun 2003
    Posts
    9,950
    Quote Originally Posted by ActionDave View Post
    Burndy YC4C6 less than $6 if you have the tool or can borrow one.
    Tom
    TBLO
  9. #9
    Join Date
    Dec 2013
    Kansas Cty, Mo, USA
    Posts
    478
    Don't call me stupid, but I've wondered about using a swaging tool and aluminum crimp sleeves. The kind you would use for wire rope or Airline cable.
    Never done it, but I thought about it in the past
  10. #10
    Join Date
    Aug 2013
    New York, NY
    Posts
    494
    Quote Originally Posted by James L View Post
    Funny you mention that. Last spring, I had to extend a Ufer connection to feed a new panel location. #4 wire fits a 3/16" oval copper Nicopress sleeve. Perfectly. Not a listed splice, but DEFINITELY irreversible and low resistance.
    I did this at my parents' house; I sleep just fine knowing how I did this splice.
    SceneryDriver
Posting Permissions
  • You may not post replies
  • You may not edit your posts
