Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
Thread: Garage and outside receptacles
  1. #11
    Join Date
    Apr 2003
    Fort Collins, Colorado
    Posts
    1,602
    2017 NEC 210.11(C)(4) exception allows it as long as the receptacle is readily accessible.
    Ron
  2. #12
    Join Date
    Jul 2005
    LA basin, CA
    Posts
    1,626
    Quote Originally Posted by rcarroll View Post
    MWBCs feeding a garage sub-panel, may also satisfy the dedicated branch circuit, outside circuits, and Energy Code / Green Codes for Car-charging raceways.
    Roger Ramjet NoFixNoPay
  3. #13
    Join Date
    Feb 2003
    Somewhere over the rainbow
    Posts
    3,250
    As stated earlier, it is allowed to have the indoor receptacle also power the outdoor receptacle. 210.11(C)(4) new section for the 2017 NEC
    Edward
    The only thing I know, is the progressive discovery of my ignorance
  4. #14
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,155
    Quote Originally Posted by edward View Post
    Yes, my earlier post said the 2017 when it should have said 2014. The 2017 added the exception that
    Ron first mentioned.
    Rob
  5. #15
    Join Date
    Jun 2012
    NW Ohio
    Posts
    942
    Although it would be nice if 210.52(g)(1) would refer to the circuit requirement and exception found at 210.11(c)(4)
  6. #16
    Join Date
    Jun 2017
    Burkburnett,tx
    Posts
    21
    Quote Originally Posted by mopowr steve View Post
    Agreed
  7. #17
    Join Date
    Jan 2007
    Posts
    3,033
    Quote Originally Posted by ramsy View Post
    I'd have to say that a MWBC feeding a garage sub-panel would actually be considered a feeder.
    JAP>
  8. #18
    Join Date
    Oct 2017
    Tyler, TX, USA
    Posts
    4
    210.11(C)(4) Exception
    I believe the 2017 NEC permits "readily accessible outdoor receptacle outlets for the garage circuit in the Exception to 210.11(C)(4).
  9. #19
    Join Date
    Jul 2005
    LA basin, CA
    Posts
    1,626
    Roger that, especially if exceeding 20 Amps
  10. #20
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    7,693
    There is an exception for readily accessible receptacles in that new section take a look at that
    Moderator-Washington State
    Ancora Imparo
Posting Permissions
  • You may not post replies
  • You may not edit your posts
