Results 1 to 9 of 9
Thread: gfci receptacle location kitchen fridge and laundry location??
  1. #1
    Join Date
    Feb 2006
    Jersey
    Posts
    2,154
    For the behind the washer/dryer receptacle and the behind refrigerator receptacle (when within 6 ' of sink) needing gfci protection, has the common practice been installing a gfci receptacle on a wall anywhere local in the kitchen or laundry but not behind the appliance OR putting a combo afci-gfci breaker in (do they work and are not glitchy)?
    Wondering how you guys have been handling it?
    Thank you
    " I'm at a crucial part of my painting "...........Monika Danneman
  2. #2
    Join Date
    Feb 2003
    Somewhere over the rainbow
    Posts
    3,250
    The GFCI has to be accessible. So anywhere you put as long as it is accessible you are OK.
    Edward
    The only thing I know, is the progressive discovery of my ignorance
  3. #3
    Join Date
    Nov 2016
    Kennewick
    Posts
    63
    I just do the afgf breakers. Because here we use the 2017 NEC and all those area require AFCI protection. A GFCI tamper is about 18 an AFCI is about 47 and an afgf is about 45 so in a price perspective it's a no brained plus the connections on gfcis fail a lot. Oh and they work extremely well.
  4. #4
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,155
    Quote Originally Posted by ritelec View Post
    Thank you
    I would use a GFCI breaker for the refrig. In NJ you do not need AFCI protection for the kitchen.
    Rob
  5. #5
    Join Date
    Feb 2006
    Jersey
    Posts
    2,154
    Quote Originally Posted by infinity View Post
    That's good to know. I will look but would that be in the same place where the addendums are for gfci protecting requirements ?
  6. #6
    Join Date
    Feb 2006
    Jersey
    Posts
    2,154
    That location thing was in my head. But I'm actually headed out to install a microwave and DW circuit for someone ( in jersey )
    No afci is required ??
    Gfci the DW and also the microwave if the recept is within 6 ' of the sink ?
    Inside cabinet recepts are accessible.
    Confirming.
    Thank you
  7. #7
    Join Date
    Apr 2003
    Fort Collins, Colorado
    Posts
    1,602
    Quote Originally Posted by edward View Post
    As of the 2011 NEC the GFCI protection is required to be readily accessible. The 2017 code explains how you can measure the 6' requirement.
    Ron
  8. #8
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,155
    Confirming.
    Thank you
    NJ amendments:
    iii. In Section 210.12(A), entitled "Arc-Fault Circuit-Interrupter Protection. Dwelling Units," "kitchens" and "laundry areas" shall be deleted.
    Rob
  9. #9
    Join Date
    Feb 2006
    Jersey
    Posts
    2,154
    Thank you !!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
