Results 1 to 8 of 8
Thread: Running wires inside Support trusses
  1. #1
    Join Date
    Jul 2016
    US
    Posts
    188
    What’s everyone’s thoughts on installing low voltage wires inside the v notch on roof trusses that are 5 feet apart is it considered a support means ?
  2. #2
    Join Date
    Oct 2007
    New Jersey
    Posts
    5,841
    I suppose that in principal there's no issue, assuming 5 foot spacing is sufficient support. However, the flanges of the bar joist might wear through the cable as random air current and building movement causes things to shift about.
    Consider using Caddy's lock rod product with their HP J-Hook product.
  3. #3
    Join Date
    Jan 2007
    Posts
    3,531
    Quote Originally Posted by bluecollar84 View Post
    It's doubtful that the Data Cabling guys are going to take the time to snake their cables through the V notches on the roof trusses every 5' apart above a drop ceiling.
    JAP>
  4. #4
    Join Date
    Oct 2007
    New Jersey
    Posts
    5,841
    Quote Originally Posted by jap View Post
    JAP>
    That's what this is for:
    Name:  Greenlee Cablecaster.jpg
  5. #5
    Join Date
    Jan 2007
    Posts
    3,531
    Quote Originally Posted by gadfly56 View Post
    Like I said........
    Our guys would have it pulled out while the guys using that were still trying to get it un-hung from the 1st bar joist.
    JAP>
  6. #6
    Join Date
    Oct 2007
    New Jersey
    Posts
    5,841
    Like I said........
    JAP>
    Well, make up your mind. Are they snaking it through the "V's" or not? Or using the J-hooks I suggested?
  7. #7
    Join Date
    Jan 2007
    Posts
    3,531
    Well from the looks of the picture they're not doing anything yet.
    JAP>
  8. #8
    Join Date
    Jun 2003
    Hawthorne, New York NEC: 2014
    Posts
    3,651
    Easier to use J hooks attached to the bottom of the trusses because you can just lay in the bundle. But if you want to there would be no problem running everything through the trusses, especially when you have only one or two runs that wouldn't warrant installing J hooks.
    -Hal
Posting Permissions
  • You may not post replies
  • You may not edit your posts
