View Poll Results: Which side should a dimmer switch be installed on?
Voters
2. You may not vote on this poll
  • Installed on LV side
    0 0%
  • Installed on HV side
    2 100.00%
Results 1 to 6 of 6
Thread: Recommendations for 60w dimmable driver
  1. #1
    Join Date
    Oct 2017
    Ohio
    Posts
    6
    Installing LED tape for undercabinet lighting.
    Here's the equipment I'm using:
    -5 runs going to basement below kitchen, about 12 feet each. 16/2 CL2 wire
    -1 run going from backsplash switch to basement. This can be HV or LV
    12v LED Tape:
    SMD3528 4.8w/meter
    -or-
    SMD2835 12w/meter
    Driver:
    Class 2 12v 45w or 60w dimmable driver
    -or-
    Class 2 12v 45w or 60w non-dimmable driver
    I have a couple questions here:
    1. What is the standard and preferred method of installing a switch? HV or LV side?
    Install dimmer switch on LV side of driver:
    Pros:
    -Possibly cheaper driver
    -Easier to install RGB controller later
    Cons:
    -Increased distance of circuit, increases voltage drop
    Install dimmer switch on 120v side of driver:
    Pros:
    -Possibly cheaper switch
    -Less voltage drop on LV side
    Cons:
    -Expensive dimmable drivers
    2. Does anyone have recommendations for dimmable drivers?
    Armacost has a 45w dimmable driver I'm unable to find their 60w driver.
    I'd need to buy multiple drivers if I went with the newer SMD2835 LEDs.
  2. #2
    Join Date
    Aug 2015
    Texas
    Posts
    104
    https://www.amazon.com/gp/aw/d/B01IY81HNS/ref=pd_aw_sim_60_of_17?ie=UTF8&psc=1&refRID=6JENHR NYZBNF0GNTYE4P
  3. #3
    Join Date
    Aug 2015
    Texas
    Posts
    104
    Sorry that last one is not dimmable
  4. #4
    Join Date
    Dec 2013
    Kansas Cty, Mo, USA
    Posts
    478
    Here's one that is listed at 120 watts. I don't think I would try to go that high because it runs hot, but I have loaded it to about 90 Watts 4 LED ribbon in a display case.
    It works with led/cfl dimmer, and I've used Lutron Maestro with great success.
    https://smile.amazon.com/dp/B01EXLZ0...ing=UTF8&psc=1
  5. #5
    Join Date
    Feb 2003
    San Jose, CA
    Posts
    1,460
    Quote Originally Posted by James L View Post
    What wiring method did you use with this driver?
    The driver linked is not a Listed Class 2 supply. You would need to use a Chapter 3 wiring method and the fixtures/strips would need to be listed for using a non Class 2 driver. Most LED fixtures/strips are only listed for use with Class 2 drivers.
    Curt Swartz
    Electrical Contractor
  6. #6
    Join Date
    Oct 2017
    Ohio
    Posts
    6
    Quote Originally Posted by curt swartz View Post
    Agreed. I will only be installing a Class 2 driver.
    Seems like my best option is a 120v dimmer in front of the driver. I'll either use 2 45w armacost dimmable drivers or the 60w dimmable driver, depending on which light strips I go with.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
